Vertex Connect Crashes Blender 2.8
Windows 10 NVidia GTX 1050 TI OC 4Gb
Broken: blender-2.80.0-git.c4c62e6df55-windows64
Worked: Blender 2.79b Offical release
When in edit mode, accessing "Vertex Connect" with F3 due search let´s Blender 2.8 crash and close! (Blend File created with the given Blender 2.8 Build.)
Load Blend file. get into edit mode. use F3 or space and than search for "Vertex Connect". Klick it and Blender Crashes and Closes.
Cannot reproduce here.
  • Does this happen when you load factory settings?
  • Do you get any (error) messages when running from the commandline (with the -d option)?
Philipp Oeser (lichtwerk) triaged this task as Needs Information from User priority.Nov 2 2018, 2:46 PM
Marking as incomplete until we have an answer...
To Point ONE! Yes it happens!
second...
I get this, even when turned blender already in point one to factory settings.
E:\blender-2.80.0-git.c4c62e6df55-windows64>blender.exe -d
Switching to fully guarded memory allocator.
Blender 2.80 (sub 29)
Build: 01/11/2018 18:17 Windows Release
argv[0] = blender.exe
argv[1] = -d
read file C:\Users\silen\AppData\Roaming\Blender Foundation\Blender\2.80\config\userpref.blend
  Version 280 sub 29 date 2018-11-02 01:04 hash c4c62e6df55
Read prefs: C:\Users\silen\AppData\Roaming\Blender Foundation\Blender\2.80\config\userpref.blend
read file
  Version 280 sub 24 date unknown hash unknown
found bundled python: E:\blender-2.80.0-git.c4c62e6df55-windows64\2.80\python
Read blend: H:\Blender\Blender2_8\Drone\drone.blend
read file H:\Blender\Blender2_8\Drone\drone.blend
Pass : Edit Mesh Face Overlay Pass, Uniform 'viewportSize' not found!
Pass : Edit Mesh Face Overlay Pass, Uniform 'edgeScale' not found!
Pass : Edit Mesh Face Overlay Pass, Uniform 'dataBuffer' not found!
Error   : EXCEPTION_ACCESS_VIOLATION
Address : 0x00007FF746C15FF4
Module  : E:\blender-2.80.0-git.c4c62e6df55-windows64\blender.exe
I see the crash when I click on the other vertex across from the initially selected one, and then run Vertex Connect ( not Vertex Connect Path ).
Here's the call stack, and watch for the variable causing the issue...
Bastien Montagne (mont29) raised the priority of this task from Needs Information from User to Normal.
Cannot reproduce crash here either, on Linux debian64…
I'm still seeing this on the latest version, try selecting this vertex before running Vertex Connect
Hm, OK seems there was indeed a reason for something I removed (blush -- see rB0f4064c66ff8).
[running vertex connect with a single vertex was not on the radar...]
Will correct shortly.
