Wireframe mode bugs #57636
Reference: blender/blender#57636
Win 7 64 Pro, GTX 1070, Blender 2.8
2.8 alpha 2 Hash:
c4c62e6df5
Playing with 'Z' key, switching between viewport modes after a while hitting the 'wireframe' pie forgets to do anything.
Added subscriber: @AlmaTalp
Added subscriber: @brecht
I don't have this problem, can you give more specific steps to redo the problem? Or attach a .blend where it is stuck in a particular mode?
I try to record it and upload as a GIF, I just played with the default cube, nothing has been changed, not scene-specific issue IMHO.
OK, I tested, it is partially a bug, also UX.
The problem was caused by the fact that after I switched to Xray mode and then I switched back to Wireframe mode it did not reset the X-ray mode (which is logical in some way, but in some other way it is not), also I think that the display of which modes area active is not so 'smooth'.
What I see it as a solution:
+1: I also would consider to forget using Pie menu for this. Personally I find using Pie menus as a 'trend', while it is not necessary at all and slows down visual operations.
Depending on the amount of choices I used to find Special menu-like ('W') solutions far more effective; something similar is what one of the 3rd party developers uses
This is an animated GIF!
Added subscriber: @lichtwerk
Also cannot get it to a state where pie is showing XRay OFF (even though it is ON).
(so for me 1. doesnt even have to be corrected, it is correct)
Is this still an issue with latest buildbot builds?
Added subscriber: @mont29
Hello Bastien, do you need info/data from the devs on this? Thx.
In the screenshot X-Ray is not on, the edges on the backside of the cubes are obscured which means it is indeed off. There's just no bug here as far as I can tell, only suggestion for a different UI, which we don't track in bug reports.
Thanks, Brecht.
Now I understand, nut I think it is a very inefficient solution. While working when I hit 'Wireframe', I want to see a see-through wireframe, not hitting another button for 'X-Ray'. As it is a vital function, I suggest to make an additional pie where it happens together (also with hotkey) from UX aspect. I cannot find simple wireframe without xray useful at all for daily workflow; even in cases when it could be handy it is more rare than the case we need see-through wireframes (based on more than 20 years in archviz/game asset and as someone who works hard on putting Blender into focus with leaving AD products.
Thanks.
X-Ray is on in wireframe mode by default, and off in solid mode. The settings are decoupled, so if you never toggle X-Ray in wireframe mode it should do what you want?
I will check if I use the latest 2.8, but I answer it differently.
I would like a single hotkey/pie to work in the same way as in 2.79 when switching to wireframe mode as the 'basic' behaviour what results full see-through wireframe for the entire scene.
Now the X-Ray settings affect hidden line visibility AFAIK in wireframe mode, with making an 'illusion' the x-ray is off.
I could make a screenshot if you need (but from a new 2.8 if it was a bug).
Ok, so it works as it should, but it heavily affects the classic wireframe function (still can't see if will it cause a conflict or not).
Left image: Wire on, X-Ray on with value= 1 (which makes no sense to use X-Ray)
Right image: the same with X-Ray = 0
So both logic works, but See-Through Wireframe mode (as it called under other apps, shortened to 'Wireframe' should be the default with an X-Ray = 0 in my opinion.
