UV selection not visible if behind unselected UVs #57650
Closed
opened 2018-11-06 11:57:32 +01:00 by Philipp Oeser · 9 comments
Member
Fedora 29, 970m
Broken: a817613be5 and previous 2.8
Worked: 2.79 master
In 2.8 a selected UV is not visible if it is "behind" an unselected UV
UVSelectionInvisible.blend
  • open attached file
  • switch to UV Edit mode in UV/Image Editor
  • looks like no UV is selected (but one is -- hit G to move it to see)
  • open file in 2.79: selection is visible there
**System Information** Fedora 29, 970m **Blender Version** Broken: a817613be5 and previous 2.8 Worked: 2.79 master **Short description of error** In 2.8 a selected UV is not visible if it is "behind" an unselected UV **Exact steps for others to reproduce the error** [UVSelectionInvisible.blend](https://archive.blender.org/developer/F5407096/UVSelectionInvisible.blend) - open attached file - switch to `UV Edit` mode in UV/Image Editor - looks like no UV is selected (but one is -- hit `G` to move it to see) - open file in 2.79: selection is visible there
Author
Member
Added subscriber: @lichtwerk
Clément Foucault was assigned by Philipp Oeser 2018-11-06 11:58:20 +01:00
Author
Member
Added subscriber: @fclem
Author
Member
@fclem: mind having a look?
Added subscribers: @WilliamReynish, @brecht
This is because of an optimization. The only way to have correct rendering is to render everything twice. I don't know if we want this? @WilliamReynish @brecht
I think this is relatively important, overlapping UVs are common.
Is it possible to do this in a single pass with a Z-buffer, drawing selected UVs with a higher Z value?
I think this is relatively important, overlapping UVs are common. Is it possible to do this in a single pass with a Z-buffer, drawing selected UVs with a higher Z value?
Yes it is possible. However we need to give up on Antialiasing of the points in this case (which is not really a big deal).
This issue was referenced by 28b06b6a05
This issue was referenced by 28b06b6a05f7e0efb307aa3f4d2d609c9162358c
Reference: blender/blender#57650
