Blender 2.8 vs 2.79 Displacement Inconsistencies #57784
Reference: blender/blender#57784
Windows 10 64 Bit
Ryzen 7 1700
Geforce GTX 1070
16GB RAM
Broken: (2.8
2c2c996a1b
(2.80.30))Worked: 2.79b
In Blender 2.8, a displacement shader I had used in the past to simulate light fur on characters works differently. This might be because of my misunderstanding of the updates to displacement, but I will describe it nonetheless.
This is the displacement node setup with a generic Principled BSDF rendered out. It creates a slight amount of bumpiness on the surface that lightly emulates fur with a low performance and setup cost.
In Blender 2.8 however, the exact same setup (the bright/contrast node goes into the displacement output) causes the object to become offset, while also not doing anything to the surface.
I read that I'd have to add a new displacement node between the texture itself and the displacement node, and while doing this fixed the offset, it didn't do anything to the texture of the mesh. It just lightly deformed parts of it. Upping settings just did that more.
I tried attempting to use a normal map into the Principled BSDF to make a similar effect, but a normal map approach looks far different than the original.
I understand this may due to changes within how displacement functions, and if so, I'd love to learn the changes, although I expect that to be covered more in 2.8.
Added subscriber: @Cooly568
Added subscriber: @brecht
By default Cycles now does actual displacement of the surface, rather than bump mapping. For this you need enough geometry subdivision to see the details.
You can change it to use bump mapping as before in the material properties > settings panel > displacement method. When opening the 2.79 file in 2.80 the material is automatically converted to use this and insert the displacement node.
Ahhh I see it's a setting on the material properties, understood, thanks for clearing that up!
Added subscriber: @fulviobosco
I have the same issue but i don't undertsand the solution
Hi Cooly, I have the same issue but i don't undertsand the solution, can you help? Is not a bug the offset of the object then?
