import bpy initializes CUDA drivers and crashes forked processes for transferring data to GPU #57813
Reference: blender/blender#57813
OS: All Unix-based OSes
Python version: 3.x
Graphics card: All NVIDIA graphics cards
I guess this should be applicable to any version of Blender with CUDA support
I recently ran into an issue when trying to move my data to GPU using PyTorch 's Python API. By reading a couple of threads[- x][- x][- x] I noticed that CUDA is not fork-safe unfortunately. The only way the problem can get resolved is by not calling any
cuInit()
driver before calling afork
ed process (it looks like you can do whatever you want in thefork
ed process without causing this issue).After some trials and errors I realized that doing
import bpy
is causing this issue for me as I guess the import process is calling thecuInit()
function to initialize CUDA drivers somewhere while getting loaded. In PyTorch, they avoided any call that causes CUDA initialization until such a call is actually needed and they called this fix Lazy Init. I'm not guessing what is happening exactly when doingimport bpy
but I guess this problem can get resolved if the call tocuInit()
is only done when people have to change any settings related to the GPU or they explicitly click on GPU rendering in Cycles or basically do anything that clearly points that people are going to use GPU for something (including clicking on EEVEE to start realtime rendering)Here is a potentially helpful comment from someone in PyTorch's Slack channel who has a better idea of what's happening under the hood:
P.S. I'm not entirely sure but this might also be relevant to this bug or this bug that I reported earlier this year.
python3 -m pip install torch
or
conda install pytorch
Compile Blender (master branch) as Python module with the following CMake flags:
Note that I manually change
PYTHON_VERSION_MIN="3.7"
ininstall_deps.sh
to `PYTHON_VERSION_MIN="3.6".Then in Python:
Added subscriber: @AmirS
blender/blender-addons#54561 was marked as duplicate of this issue
Added subscriber: @brecht
You can compile with
WITH_CYCLES_DEVICE_CUDA=OFF
orWITH_CYCLES=OFF
.@brecht Sorry but I forgot to remove that line where I say compiling Blender without CUDA would also be okay. However, this is not the solution I was looking for here (I was looking for such solution on devtalk). Could you please reopen this and look into it?
The bpy module is not an officially supported feature, and you can compile it in such a way to disable CUDA. So I do not consider this a bug to be handled in the tracker.
@brecht But I don't think it's necessarily about the bpy module. As far as I know you can also compile Blender so that it uses the system's Python internally. If there is any goal to make Blender usable by researchers I think this is definitely one thing many researchers who do AI research need in.
@brecht Also, I don't this issue and the import order issue are duplicates ... . I would appreciate if the developers can be more patient with issues that have the sentences like "I compiled Blender as Python module" and don't close/ignore them immediately. In the world of researchers using Blender as Python module is an amazing feature.
This issue is the same as the other one, it's a conflict with both Cycles and PyTorch using CUDA.
If you want to use the unsupported Python module, or if you want to use Blender for AI research, then you are free to do so. But Blender is primarily a tool for artists, and that means we set priorities and can consider issues like this outside of what we spend time supporting.
It looks like the changes here resolve this issue and Blender also has lazy initialization for CUDA now.
