Undo (ctrl-z) does not work for Property value changes while in Edit Mode #57897
2 Participants
Reference: blender/blender#57897
Windows 10, GeForce VTX 1070
2.79b
Start a new project, with a default cube mesh in the scene. Switch into edit mode (tab). In the Properties window, select the Object tab. Make any adjustment to the Transform (position, rotation, or scale), then press ctrl-z. The transform change will not undo. The same is true for nearly any Property change. While in Object Mode, undo works fine for properties, but in Edit mode is appears to be completely ineffective.
This issue is a concern for two reasons. First, it makes it difficult to trial property changes, as now I can't undo them. And second, it means that I often end up undoing a mesh change.
Added subscriber: @dangoyette
Added subscriber: @mont29
That is known limitation of our undo system, in Edit mode do not tweak Object properties if you want to be able to undo them… Afraid there is nothing else to do here, thanks for the report anyway.
