Blender 2.8: Make duplicates real does nothing. #58118
Closed
opened 2018-11-28 18:39:09 +01:00 by Mauricio Marinho · 13 comments
Ubuntu 18.04
GTX 970 4gb
i7-8700k
Broken: (example: 2.8 2018-11-28 6fd5f95call)
Convert button in particle systems with objects for hairs does nothing (couldn't find any report on it yet, sorry if duplicate)
Add cube as emitter, add particle system to it and set it to hair, make it render objects as strands. Click convert on the particle modifier or use "Make duplicates real" operator.
makeduplicatesrealbug.blend
**System Information** Ubuntu 18.04 GTX 970 4gb i7-8700k **Blender Version** Broken: (example: 2.8 2018-11-28 6fd5f95call) Worked: (optional) **Short description of error** Convert button in particle systems with objects for hairs does nothing (couldn't find any report on it yet, sorry if duplicate) **Exact steps for others to reproduce the error** Add cube as emitter, add particle system to it and set it to hair, make it render objects as strands. Click convert on the particle modifier or use "Make duplicates real" operator. [makeduplicatesrealbug.blend](https://archive.blender.org/developer/F5746505/makeduplicatesrealbug.blend)
Added subscriber: @MauricioMarinho
#58282 was marked as duplicate of this issue
Member
Added subscriber: @lichtwerk
Member
Confirmed, checking...
Sergey Sharybin was assigned by Philipp Oeser 2018-11-29 15:24:42 +01:00
Member
Added subscriber: @Sergey
Member
Looks like a problem with base->object->transflag
On file load this gets set once in BKE_object_handle_data_update()
  • ob->transflag |= OB_DUPLIPARTS;
in get_dupli_generator() (for info stats)
  • ob->transflag is still 2048
But then in object_duplicates_make_real_exec():
  • if I check CTX_data_active_object(C)->transflag it is 0
  • thus in selected_editable_bases iterator: base->object->transflag is 0
Thus it earlies out in make_object_duplilist_real():
if (!(base->object->transflag & OB_DUPLI)) {
	return;
@Sergey: could you check on this?
Looks like a problem with `base->object->transflag` On file load this gets set once in `BKE_object_handle_data_update()` - `ob->transflag |= OB_DUPLIPARTS;` in `get_dupli_generator()` (for info stats) - ob->transflag is still 2048 But then in `object_duplicates_make_real_exec()`: - if I check `CTX_data_active_object(C)->transflag` it is 0 - thus in selected_editable_bases iterator: `base->object->transflag` is 0 Thus it earlies out in `make_object_duplilist_real()`: ``` if (!(base->object->transflag & OB_DUPLI)) { return; } ``` @Sergey: could you check on this?
Member
Added subscriber: @Adrian.kubasa
Added subscriber: @JanKopidol
Also maybe related to this issue ...
Also maybe related to [this issue ](https://developer.blender.org/T58481) ...
Added subscriber: @kirberoid
Removed subscriber: @kirberoid
This issue was referenced by cf2e35fcfe
This issue was referenced by cf2e35fcfe31aa2c1836f51d1206901b4be6aeba
6 Participants
Reference: blender/blender#58118
