Spin tool top bar settings don't apply #58199
Closed
opened 2018-11-29 22:15:23 +01:00 by Alaska · 11 comments
Member
System Information:
CPU: Ryzen 5 2600
GPU: RX 570 4GB
OS: Windows 10 Home
Broken: Blender 2.8 Beta 26d5a3625e
Short description of error:
The spin tool and spin tool duplicate in edit mode ignore step settings changes in the top bar.
Exact steps for others to reproduce the error:
  1. Open Blender and switch to the 3D viewport.
  2. Create an object if there isn't one already.
  3. Enter edit mode on the object.
  4. From the tool bar, select spin or spin duplicate.
  5. In the top bar, adjust the step settings for the spin tool. I'd recommend changing the steps to 1.
  6. Use the gizmo on your object and notice that it's still spinning with nine steps (or the same number you set in the redo panel the last time you used the tool).
**System Information:** CPU: Ryzen 5 2600 GPU: RX 570 4GB OS: Windows 10 Home **Blender Version** Broken: Blender 2.8 Beta 26d5a3625ed **Short description of error:** The spin tool and spin tool duplicate in edit mode ignore step settings changes in the top bar. **Exact steps for others to reproduce the error:** 1. Open Blender and switch to the 3D viewport. 2. Create an object if there isn't one already. 3. Enter edit mode on the object. 4. From the tool bar, select spin or spin duplicate. 5. In the top bar, adjust the step settings for the spin tool. I'd recommend changing the steps to 1. 6. Use the gizmo on your object and notice that it's still spinning with nine steps (*or the same number you set in the redo panel the last time you used the tool*).
Author
Member
Added subscriber: @Alaska
Added subscriber: @WilliamReynish
William Reynish self-assigned this 2018-11-29 22:31:12 +01:00
Not a bug. Use the panel in the bottom to adjust.
Author
Member
Alaska reopened this issue 2018-11-29 23:03:03 +01:00
Author
Member
@WilliamReynish
I would consider this a bug as every other tool (take the bevel tool for example) respects edits made in the top bar prior to the tools use. And if this is working as expected, then why is the steps option included in the top bar if it does nothing?
@WilliamReynish I would consider this a bug as every other tool (take the bevel tool for example) respects edits made in the top bar prior to the tools use. And if this is working as expected, then why is the steps option included in the top bar if it does nothing?
Added subscriber: @ideasman42
Yes you are right. @ideasman42 One for you
William Reynish removed their assignment 2019-01-22 13:13:54 +01:00
Campbell Barton was assigned by William Reynish 2019-01-22 13:13:54 +01:00
This issue still exists today: The Spin tool Steps property doesn't work when set from the top bar.
This issue was referenced by 6dfe6b4f19
This issue was referenced by 6dfe6b4f196d20be24a0c71dcc90ed5569f9b565
Reference: blender/blender#58199
