Tilt curve point (tool menu) do not works #58223
Closed
opened 2018-11-29 23:08:23 +01:00 by Petr Pluháček · 5 comments
Tilt curve point (select from tool menu) do not works when LMB select mode enabled
Steps to reproduce:
  • switch to LMB select mode
  • add curve
  • switch to edit mode
  • select curve point
  • click to "tilt" button in tool menu
  • try hold LMB and move
Expected behaviours: Tilt manipulator will appear and dragging LMB will change tilt of curve point.
Present behaviours: No tilt manipulator will appear, hold and drag LMB just move curve point
Notes:
  • When RMB select mode enabled, no tilt manipulator will appear but tilting is possible as expected.
  • Ctrl+T works properly
Official 2.80 beta for Linux 64, from 2018-11-28
Tilt curve point (select from tool menu) do not works when LMB select mode enabled Steps to reproduce: * switch to LMB select mode * add curve * switch to edit mode * select curve point * click to "tilt" button in tool menu * try hold LMB and move Expected behaviours: Tilt manipulator will appear and dragging LMB will change tilt of curve point. Present behaviours: No tilt manipulator will appear, hold and drag LMB just move curve point Notes: * When RMB select mode enabled, no tilt manipulator will appear but tilting is possible as expected. * Ctrl+T works properly **Blender Version** Official 2.80 beta for Linux 64, from 2018-11-28 ![tilt curve point.png](https://archive.blender.org/developer/F5760325/tilt_curve_point.png)
Added subscriber: @Pitris
Added subscriber: @WilliamReynish
Brecht Van Lommel was assigned by William Reynish 2018-11-29 23:34:30 +01:00
Correct, this works in right click select, but not left click select. Probably a keymap issue.
This issue was referenced by 234c112971
This issue was referenced by 234c1129715a022b5ff95ed3dcd8e275e3661f8c
Reference: blender/blender#58223
