Multiview not working with OpenGL render using scene settings #58517
Closed
opened 2018-12-02 14:18:35 +01:00 by Shinsuke Irie · 8 comments
Member
Operating system: Ubuntu 18.10
Graphics card: NVIDIA Geforce GTX 1070
Broken: 2.79b (release and master 335e1b507b), 2.80 (8c620c8e2b and 925380050d)
When running bpy.ops.render.opengl(view_context=False), the multiview settings (bpy.context.scene.render.use_multiview = True, etc.) are ignored unreasonably.
multiview_render_test.blend
  • Start Blender from command line
  • Open multiview_render_test.blend
Click "Run Script" button in the Text Editor
Console output of the result is as follows:
=== Multiview render tests ===
(1) Single Frame
a. Not OpenGL
Saved: '/tmp/test_L.png'
Saved: '/tmp/test_R.png'
 Time: 00:00.19 (Saving: 00:00.12)
b. OpenGL (view_context=True)
OpenGL Render written to '/tmp/test_R.png'
c. OpenGL (view_context=False)
Saved: '/tmp/test.png'
OpenGL Render written to '/tmp/test.png'
(1) Animation
a. Not OpenGL
Saved: '/tmp/test0001_L.png'
Saved: '/tmp/test0001_R.png'
 Time: 00:00.13 (Saving: 00:00.07)
Saved: '/tmp/test0002_L.png'
Saved: '/tmp/test0002_R.png'
Saved: '/tmp/test0003_L.png'
Saved: '/tmp/test0003_R.png'
Saved: '/tmp/test0004_L.png'
Saved: '/tmp/test0004_R.png'
Saved: '/tmp/test0005_L.png'
Saved: '/tmp/test0005_R.png'
Saved: '/tmp/test0001.png'
Saved: '/tmp/test0005.png'
Saved: '/tmp/test0002.png'
Saved: '/tmp/test0004.png'
Saved: '/tmp/test0003.png'
Only OpenGL render with view_context=False did single view rendering incorrectly.
Solution
I believe the following patch fixes the bug:
diff --git a/source/blender/editors/render/render_opengl.c b/source/blender/editors/render/render_opengl.c
index 78cedf099a1..e1d081d7e15 100644
--- a/source/blender/editors/render/render_opengl.c
+++ b/source/blender/editors/render/render_opengl.c
@@ -165,10 +165,10 @@ static bool screen_opengl_is_multiview(OGLRender *oglrender)
 	RegionView3D *rv3d = oglrender->rv3d;
 	RenderData *rd = &oglrender->scene->r;
-	if ((rd == NULL) || ((!oglrender->is_sequencer) && ((rv3d == NULL) || (v3d == NULL))))
+	if ((rd == NULL) || ((v3d != NULL) && (rv3d == NULL)))
 		return false;
-	return (rd->scemode & R_MULTIVIEW) && ((oglrender->is_sequencer) || (rv3d->persp == RV3D_CAMOB && v3d->camera));
+	return (rd->scemode & R_MULTIVIEW) && ((v3d == NULL) || (rv3d->persp == RV3D_CAMOB && v3d->camera));
 static void screen_opengl_views_setup(OGLRender *oglrender)
@@ -212,7 +212,7 @@ static void screen_opengl_views_setup(OGLRender *oglrender)
 	else {
-		if (!oglrender->is_sequencer)
+		if (v3d)
 			RE_SetOverrideCamera(oglrender->re, V3D_CAMERA_SCENE(oglrender->scene, v3d));
 		/* remove all the views that are not needed */
**System Information** Operating system: Ubuntu 18.10 Graphics card: NVIDIA Geforce GTX 1070 **Blender Version** Broken: 2.79b (release and master 335e1b507b1), 2.80 (8c620c8e2b3 and 925380050d0) **Short description of error** When running bpy.ops.render.opengl(view_context=False), the multiview settings (bpy.context.scene.render.use_multiview = True, etc.) are ignored unreasonably. **Exact steps for others to reproduce the error** [multiview_render_test.blend](https://archive.blender.org/developer/F5789540/multiview_render_test.blend) - Start Blender from command line - Open multiview_render_test.blend # Click "Run Script" button in the Text Editor Console output of the result is as follows: ``` === Multiview render tests === (1) Single Frame a. Not OpenGL Saved: '/tmp/test_L.png' Saved: '/tmp/test_R.png' Time: 00:00.19 (Saving: 00:00.12) b. OpenGL (view_context=True) Saved: '/tmp/test_L.png' Saved: '/tmp/test_R.png' OpenGL Render written to '/tmp/test_R.png' c. OpenGL (view_context=False) Saved: '/tmp/test.png' OpenGL Render written to '/tmp/test.png' (1) Animation a. Not OpenGL Saved: '/tmp/test0001_L.png' Saved: '/tmp/test0001_R.png' Time: 00:00.13 (Saving: 00:00.07) Saved: '/tmp/test0002_L.png' Saved: '/tmp/test0002_R.png' Time: 00:00.13 (Saving: 00:00.07) Saved: '/tmp/test0003_L.png' Saved: '/tmp/test0003_R.png' Time: 00:00.13 (Saving: 00:00.07) Saved: '/tmp/test0004_L.png' Saved: '/tmp/test0004_R.png' Time: 00:00.13 (Saving: 00:00.07) Saved: '/tmp/test0005_L.png' Saved: '/tmp/test0005_R.png' Time: 00:00.13 (Saving: 00:00.07) b. OpenGL (view_context=True) Saved: '/tmp/test0001_L.png' Saved: '/tmp/test0002_L.png' Saved: '/tmp/test0003_L.png' Saved: '/tmp/test0004_L.png' Saved: '/tmp/test0002_R.png' Saved: '/tmp/test0001_R.png' Saved: '/tmp/test0005_L.png' Saved: '/tmp/test0004_R.png' Saved: '/tmp/test0003_R.png' Saved: '/tmp/test0005_R.png' c. OpenGL (view_context=False) Saved: '/tmp/test0001.png' Saved: '/tmp/test0005.png' Saved: '/tmp/test0002.png' Saved: '/tmp/test0004.png' Saved: '/tmp/test0003.png' ``` Only OpenGL render with view_context=False did single view rendering incorrectly. **Solution** I believe the following patch fixes the bug: ``` diff --git a/source/blender/editors/render/render_opengl.c b/source/blender/editors/render/render_opengl.c index 78cedf099a1..e1d081d7e15 100644 --- a/source/blender/editors/render/render_opengl.c +++ b/source/blender/editors/render/render_opengl.c @@ -165,10 +165,10 @@ static bool screen_opengl_is_multiview(OGLRender *oglrender) RegionView3D *rv3d = oglrender->rv3d; RenderData *rd = &oglrender->scene->r; - if ((rd == NULL) || ((!oglrender->is_sequencer) && ((rv3d == NULL) || (v3d == NULL)))) + if ((rd == NULL) || ((v3d != NULL) && (rv3d == NULL))) return false; - return (rd->scemode & R_MULTIVIEW) && ((oglrender->is_sequencer) || (rv3d->persp == RV3D_CAMOB && v3d->camera)); + return (rd->scemode & R_MULTIVIEW) && ((v3d == NULL) || (rv3d->persp == RV3D_CAMOB && v3d->camera)); } static void screen_opengl_views_setup(OGLRender *oglrender) @@ -212,7 +212,7 @@ static void screen_opengl_views_setup(OGLRender *oglrender) } } else { - if (!oglrender->is_sequencer) + if (v3d) RE_SetOverrideCamera(oglrender->re, V3D_CAMERA_SCENE(oglrender->scene, v3d)); /* remove all the views that are not needed */ ```
Author
Member
Added subscriber: @IRIEShinsuke
Clément Foucault was assigned by Sebastian Parborg 2018-12-07 16:59:23 +01:00
Clément Foucault was unassigned by Jeroen Bakker 2019-03-20 14:53:45 +01:00
Jeroen Bakker self-assigned this 2019-03-20 14:53:45 +01:00
Member
Added subscriber: @fclem
Jeroen Bakker removed their assignment 2019-03-22 09:13:16 +01:00
Dalai Felinto was assigned by Jeroen Bakker 2019-03-22 09:13:16 +01:00
Member
Added subscribers: @dfelinto, @Jeroen-Bakker
Member
@dfelinto need your guidance.
according to https://git.blender.org/gitweb/gitweb.cgi/blender.git/commit/d5f1b9c22233 viewport rendering of multi view is not supported. Is that still the case?
Would like to have your opinion as this Task might be a feature request and not a bug. So what is intended by design?
As this is a b279 issue I lowered the priority for now.
@dfelinto need your guidance. according to https://git.blender.org/gitweb/gitweb.cgi/blender.git/commit/d5f1b9c22233 viewport rendering of multi view is not supported. Is that still the case? Would like to have your opinion as this Task might be a feature request and not a bug. So what is intended by design? As this is a b279 issue I lowered the priority for now.
"Viewport Rendering doesn't support Multi-View"
That was referring to Cycles render preview. VIewport OpenGL render always worked.
The patch may be correct, let me get my head around it a bit.
> "Viewport Rendering doesn't support Multi-View" That was referring to Cycles render preview. VIewport OpenGL render always worked. The patch may be correct, let me get my head around it a bit.
This issue was referenced by 5f45cbb26e
This issue was referenced by 5f45cbb26ec853b09b88c795c9b6107425f91f8a
Thanks for the patch, committed in the 2.80 repository.
Reference: blender/blender#58517
