EEVEE camera motion blur renders only one viewport sample
Operating system: Windows 10 Pro, 64 Bit
Graphics card: GeForce GTX 1080 Ti
Broken: Date 2018-12-03 00:27, Hash: a205493426b, Branch: blender2.8
Eevee mode: When using rendered "camera view" in the viewport, it will always be rendered using 1 render sample only. The camera view ignores the global Viewport Samples settings.
If you exit the camera view and switch to the regular user perspektive view, then the global Viewport Samples are correct and the view renders as expected.
Why the camera view is ignoring the global viewport sample settings?
See my attached image,please.
EDIT: The bug appear when "Motion Blur" is activated in Eevee render settings.
Christoph Werner (Taros) renamed this task from Camera view in viewport is rendered always with 1 render sample only to Camera view ignores global eevee "Viewport Samples" settings.Dec 3 2018, 1:19 PM
Christoph Werner (Taros) renamed this task from Camera view ignores global eevee "Viewport Samples" settings to Camera view ignores global Eevee "Viewport Samples" settings.
Christoph Werner (Taros) created this task.
Brecht Van Lommel (brecht) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Dec 3 2018, 2:00 PM
Please attach a simple .blend file to reproduce the issue.
this is happening when using camera motion blur, I don't know if it's a bug or it's behaving as intended...
Conformed. Activation Motion Blur in the render settings is really the reason. Thank you for the hint. Seem to be an error.
@Brecht Van Lommel (brecht) I've attached the file to reproduce it. Please switch to "Rendered mode" in Eevee in both viewports, to see the difference. As @paul szajner (szap) mentioned: It happen when Motion Blur is enabled in Eevee the render settings. You can see the difference if you swap between Motion Blur on and off.
Brecht Van Lommel (brecht) renamed this task from Camera view ignores global Eevee "Viewport Samples" settings to EEVEE camera motion blur renders only one viewport sample.Dec 3 2018, 2:48 PM
Brecht Van Lommel (brecht) raised the priority of this task from Needs Information from User to Confirmed, Medium.
