Not possible to add shortcuts to menus from right click.
any system
any blender version
Its not possible to right click on a menu and add a shortcut to it, you have to know the bl_idname of that menu and its not exposed by hovering the mouse on it, besides all blender versions have been with this problem, it can be considered a bug,
Right click on a button and click change shortcut, It works!
Now Right click on a menu, no option appears.
Dalai Felinto (dfelinto) triaged this task as Normal priority.Dec 4 2018, 10:28 PM
This is more of a TODO than a bug. As you said yourself it has always been like this.
It is doable with a hack, using the WM_OT_call_menu operator to call the menu. Not sure if it makes sense though/
@Campbell Barton (campbellbarton) / @William Reynish (billreynish) what do you say? Should be added to UI papercuts?
Sure, if this can be done in a reasonable way, that sounds good to add.
We'd need to have special support for this kind of button.
This is more a regular todo (applies to 2.7x too)
