Circle Select Tool Bugs #58768
Reference: blender/blender#58768
Broken: 2.8 beta,
be91d4ef95
, 2018-12-04Short description of error
Using the Circle Select tool via hotkey (C) won't change the toolbar highlighted tool. Another bug is that selecting it via hotckey blocks you from clicking any UI/menu items. But manually selecting it from the toolbar works just fine.
Added subscriber: @Gilberto.R
Added subscribers: @WilliamReynish, @ideasman42, @brecht, @lichtwerk
The
tool
and the [modal]operator
are still separated to a certain degree.So hotkeys are different as well [
C
for the modal operator,SHIFT+SPACE -> C
for the tool]So when you use
C
you are not entering the tool really.The tool is using the operator code, but
Havent studied the toolsystem in depth, but I guess it would be good to
I could look into adding the tool keymap for the radius, but would first ask for opinions of @WilliamReynish , @ideasman42 , @brecht
The currently works as intended. This way the modal operators can be used when any tool is active.
However, we have discussed several things related to this, including a preference for all the hotkeys to map to the active tools instead.
We could perhaps add a shortcut to set the circle select size, although it’s problematic because the keyboard is not free. When a tool is active, it doesn’t override the entire keyboard, which would make it impossible to use shortcuts then.
