Cloud add-on: make BAT-packing faster #58781
Closed
opened 2018-12-05 11:20:04 +01:00 by Sybren A. Stüvel · 3 comments
Some ideas:
  • Store compressed blend file next to original (or in a special cache dir) and compare timestamps, to avoid recompressing unchanged files.
  • Store all files in a cache dir on /render named after their MD5 sum, and link those into the BAT pack, instead of copying the same files again and again.
Some ideas: - Store compressed blend file next to original (or in a special cache dir) and compare timestamps, to avoid recompressing unchanged files. - Store all files in a cache dir on /render named after their MD5 sum, and link those into the BAT pack, instead of copying the same files again and again.
Author
Owner
Added subscriber: @dr.sybren
Author
Owner
Author
Owner
A new generation of Flamenco (version 3.0) is in development (in the main branch at https://developer.blender.org/diffusion/F/), so all issues with Flamenco version 2 or older will be archived.
A new generation of Flamenco (version 3.0) is in development (in the `main` branch at https://developer.blender.org/diffusion/F/), so all issues with Flamenco version 2 or older will be archived.
1 Participants
Reference: studio/flamenco#58781
