Blender causes BSOD
Closed, InvalidPublic
Blender 2.79 (sub 0) System Information
Blender:
version: 2.79 (sub 0), branch: master, commit date: 2018-03-22 14:10, hash: f4dc9f9d68b, type:
build date: Thu 03/22/2018, 09:59 AM
platform: Windows
binary path: 'C:\\Program Files\\Blender Foundation\\Blender\\blender.exe'
build cflags: /W3 /w34062 /wd4018 /wd4146 /wd4065 /wd4127 /wd4181 /wd4200 /wd4244 /wd4267 /wd4305 /wd4800 /we4013 /we4431 /DWIN32 /D_WINDOWS /W3 /nologo /J /Gd /MP /openmp
build cxxflags: /W3 /w34062 /wd4018 /wd4146 /wd4065 /wd4127 /wd4181 /wd4200 /wd4244 /wd4267 /wd4305 /wd4800 /we4013 /we4431 /DWIN32 /D_WINDOWS /W3 /GR /EHsc /nologo /J /Gd /MP /EHsc /openmp
build linkflags: /MACHINE:X64 /SUBSYSTEM:CONSOLE /STACK:2097152 /INCREMENTAL:NO /NODEFAULTLIB:msvcrt.lib /NODEFAULTLIB:msvcmrt.lib /NODEFAULTLIB:msvcurt.lib /NODEFAULTLIB:msvcrtd.lib /ignore:4049 /ignore:4217 /ignore:4221
build system: CMake
Python:
version: 3.5.3 (default, May 20 2017, 19:10:40) [MSC v.1800 64 bit (AMD64)]
paths:
'C:\\Program Files\\Blender Foundation\\Blender\\2.79\\scripts\\addons_contrib'
'C:\\Users\\Windows\\AppData\\Roaming\\Blender Foundation\\Blender\\2.79\\scripts\\addons'
'C:\\Program Files\\Blender Foundation\\Blender\\2.79\\scripts\\addons'
'C:\\Program Files\\Blender Foundation\\Blender\\2.79\\scripts\\startup'
'C:\\Program Files\\Blender Foundation\\Blender\\2.79\\scripts\\modules'
'C:\\Program Files\\Blender Foundation\\Blender\\python35.zip'
'C:\\Program Files\\Blender Foundation\\Blender\\2.79\\python\\DLLs'
'C:\\Program Files\\Blender Foundation\\Blender\\2.79\\python\\lib'
'C:\\Program Files\\Blender Foundation\\Blender'
'C:\\Program Files\\Blender Foundation\\Blender\\2.79\\python'
'C:\\Program Files\\Blender Foundation\\Blender\\2.79\\python\\lib\\site-packages'
'C:\\Program Files\\Blender Foundation\\Blender\\2.79\\scripts\\freestyle\\modules'
'C:\\Program Files\\Blender Foundation\\Blender\\2.79\\scripts\\addons\\modules'
'C:\\Users\\Windows\\AppData\\Roaming\\Blender Foundation\\Blender\\2.79\\scripts\\addons\\modules'
Python (External Binary):
binary path: 'C:\\Program Files\\Blender Foundation\\Blender\\2.79\\python\\bin\\python.EXE'
version: Python 3.5.3
Directories:
scripts:
'C:\\Program Files\\Blender Foundation\\Blender\\2.79\\scripts'
'C:\\Users\\Windows\\AppData\\Roaming\\Blender Foundation\\Blender\\2.79\\scripts'
user scripts: 'C:\\Users\\Windows\\AppData\\Roaming\\Blender Foundation\\Blender\\2.79\\scripts'
pref scripts: None
datafiles: 'C:\\Users\\Windows\\AppData\\Roaming\\Blender Foundation\\Blender\\2.79\\datafiles\\'
config: 'C:\\Users\\Windows\\AppData\\Roaming\\Blender Foundation\\Blender\\2.79\\config\\'
scripts : 'C:\\Users\\Windows\\AppData\\Roaming\\Blender Foundation\\Blender\\2.79\\scripts\\'
autosave: 'C:\\Users\\Windows\\AppData\\Roaming\\Blender Foundation\\Blender\\2.79\\autosave\\'
tempdir: 'C:\\Users\\Windows\\AppData\\Local\\Temp\\blender_a02532\\'
FFmpeg:
avcodec: '57, 64, 101'
avdevice: '57, 1, 100'
avformat: '57, 56, 100'
avutil: '55, 34, 100'
swscale: ' 4, 2, 100'
SDL:
Version: 2.0.4
Loading method: linked (WITH_SDL_DYNLOAD=OFF)
Other Libraries:
OpenColorIO: 1, 0, 9
OpenImageIO: 1, 7, 15
OpenShadingLanguage: 1, 7, 5
OpenSubdiv: 3, 1, 1
OpenVDB: 3, 1, 0
Alembic: 1, 7, 1
OpenGL:
renderer: 'Radeon 550 Series'
vendor: 'ATI Technologies Inc.'
version: '4.5.13541 Compatibility Profile Context 25.20.14007.1000'
extensions:
GL_AMDX_debug_output
GL_AMD_blend_minmax_factor
GL_AMD_conservative_depth
GL_AMD_debug_output
GL_AMD_depth_clamp_separate
GL_AMD_draw_buffers_blend
GL_AMD_framebuffer_sample_positions
GL_AMD_gcn_shader
GL_AMD_gpu_shader_half_float
GL_AMD_gpu_shader_int16
GL_AMD_gpu_shader_int64
GL_AMD_interleaved_elements
GL_AMD_multi_draw_indirect
GL_AMD_name_gen_delete
GL_AMD_occlusion_query_event
GL_AMD_performance_monitor
GL_AMD_pinned_memory
GL_AMD_query_buffer_object
GL_AMD_sample_positions
GL_AMD_seamless_cubemap_per_texture
GL_AMD_shader_atomic_counter_ops
GL_AMD_shader_stencil_export
GL_AMD_shader_stencil_value_export
GL_AMD_shader_trace
GL_AMD_shader_trinary_minmax
GL_AMD_sparse_texture
GL_AMD_sparse_texture_pool
GL_AMD_stencil_operation_extended
GL_AMD_texture_cube_map_array
GL_AMD_texture_texture4
GL_AMD_transform_feedback3_lines_triangles
GL_AMD_transform_feedback4
GL_AMD_vertex_shader_layer
GL_AMD_vertex_shader_viewport_index
GL_ARB_ES2_compatibility
GL_ARB_ES3_1_compatibility
GL_ARB_ES3_compatibility
GL_ARB_arrays_of_arrays
GL_ARB_base_instance
GL_ARB_bindless_texture
GL_ARB_blend_func_extended
GL_ARB_buffer_storage
GL_ARB_clear_buffer_object
GL_ARB_clear_texture
GL_ARB_clip_control
GL_ARB_color_buffer_float
GL_ARB_compatibility
GL_ARB_compressed_texture_pixel_storage
GL_ARB_compute_shader
GL_ARB_conditional_render_inverted
GL_ARB_conservative_depth
GL_ARB_copy_buffer
GL_ARB_copy_image
GL_ARB_cull_distance
GL_ARB_debug_output
GL_ARB_depth_buffer_float
GL_ARB_depth_clamp
GL_ARB_depth_texture
GL_ARB_derivative_control
GL_ARB_direct_state_access
GL_ARB_draw_buffers
GL_ARB_draw_buffers_blend
GL_ARB_draw_elements_base_vertex
GL_ARB_draw_indirect
GL_ARB_draw_instanced
GL_ARB_enhanced_layouts
GL_ARB_explicit_attrib_location
GL_ARB_explicit_uniform_location
GL_ARB_fragment_coord_conventions
GL_ARB_fragment_layer_viewport
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_framebuffer_no_attachments
GL_ARB_framebuffer_object
GL_ARB_framebuffer_sRGB
GL_ARB_geometry_shader4
GL_ARB_get_program_binary
GL_ARB_get_texture_sub_image
GL_ARB_gl_spirv
GL_ARB_gpu_shader5
GL_ARB_gpu_shader_fp64
GL_ARB_half_float_pixel
GL_ARB_half_float_vertex
GL_ARB_imaging
GL_ARB_indirect_parameters
GL_ARB_instanced_arrays
GL_ARB_internalformat_query
GL_ARB_internalformat_query2
GL_ARB_invalidate_subdata
GL_ARB_map_buffer_alignment
GL_ARB_map_buffer_range
GL_ARB_multi_bind
GL_ARB_multi_draw_indirect
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_occlusion_query2
GL_ARB_parallel_shader_compile
GL_ARB_pipeline_statistics_query
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_program_interface_query
GL_ARB_provoking_vertex
GL_ARB_query_buffer_object
GL_ARB_robust_buffer_access_behavior
GL_ARB_sample_shading
GL_ARB_sampler_objects
GL_ARB_seamless_cube_map
GL_ARB_seamless_cubemap_per_texture
GL_ARB_separate_shader_objects
GL_ARB_shader_atomic_counters
GL_ARB_shader_ballot
GL_ARB_shader_bit_encoding
GL_ARB_shader_draw_parameters
GL_ARB_shader_group_vote
GL_ARB_shader_image_load_store
GL_ARB_shader_image_size
GL_ARB_shader_objects
GL_ARB_shader_precision
GL_ARB_shader_stencil_export
GL_ARB_shader_storage_buffer_object
GL_ARB_shader_subroutine
GL_ARB_shader_texture_image_samples
GL_ARB_shader_texture_lod
GL_ARB_shader_viewport_layer_array
GL_ARB_shading_language_100
GL_ARB_shading_language_420pack
GL_ARB_shading_language_packing
GL_ARB_shadow
GL_ARB_shadow_ambient
GL_ARB_sparse_buffer
GL_ARB_sparse_texture
GL_ARB_spirv_extensions
GL_ARB_stencil_texturing
GL_ARB_sync
GL_ARB_tessellation_shader
GL_ARB_texture_barrier
GL_ARB_texture_border_clamp
GL_ARB_texture_buffer_object
GL_ARB_texture_buffer_object_rgb32
GL_ARB_texture_buffer_range
GL_ARB_texture_compression
GL_ARB_texture_compression_bptc
GL_ARB_texture_compression_rgtc
GL_ARB_texture_cube_map
GL_ARB_texture_cube_map_array
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_float
GL_ARB_texture_gather
GL_ARB_texture_mirror_clamp_to_edge
GL_ARB_texture_mirrored_repeat
GL_ARB_texture_multisample
GL_ARB_texture_non_power_of_two
GL_ARB_texture_query_levels
GL_ARB_texture_query_lod
GL_ARB_texture_rectangle
GL_ARB_texture_rg
GL_ARB_texture_rgb10_a2ui
GL_ARB_texture_snorm
GL_ARB_texture_stencil8
GL_ARB_texture_storage
GL_ARB_texture_storage_multisample
GL_ARB_texture_swizzle
GL_ARB_texture_view
GL_ARB_timer_query
GL_ARB_transform_feedback2
GL_ARB_transform_feedback3
GL_ARB_transform_feedback_instanced
GL_ARB_transform_feedback_overflow_query
GL_ARB_transpose_matrix
GL_ARB_uniform_buffer_object
GL_ARB_vertex_array_bgra
GL_ARB_vertex_array_object
GL_ARB_vertex_attrib_64bit
GL_ARB_vertex_attrib_binding
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_vertex_type_10f_11f_11f_rev
GL_ARB_vertex_type_2_10_10_10_rev
GL_ARB_viewport_array
GL_ARB_window_pos
GL_ATI_draw_buffers
GL_ATI_envmap_bumpmap
GL_ATI_fragment_shader
GL_ATI_separate_stencil
GL_ATI_texture_compression_3dc
GL_ATI_texture_env_combine3
GL_ATI_texture_float
GL_ATI_texture_mirror_once
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_bindable_uniform
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_compiled_vertex_array
GL_EXT_copy_buffer
GL_EXT_copy_texture
GL_EXT_depth_bounds_test
GL_EXT_direct_state_access
GL_EXT_draw_buffers2
GL_EXT_draw_instanced
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXT_framebuffer_object
GL_EXT_framebuffer_sRGB
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_histogram
GL_EXT_memory_object
GL_EXT_memory_object_win32
GL_EXT_multi_draw_arrays
GL_EXT_packed_depth_stencil
GL_EXT_packed_float
GL_EXT_packed_pixels
GL_EXT_pixel_buffer_object
GL_EXT_point_parameters
GL_EXT_polygon_offset_clamp
GL_EXT_provoking_vertex
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_semaphore
GL_EXT_semaphore_win32
GL_EXT_separate_specular_color
GL_EXT_shader_image_load_store
GL_EXT_shader_integer_mix
GL_EXT_shadow_funcs
GL_EXT_stencil_wrap
GL_EXT_subtexture
GL_EXT_texgen_reflection
GL_EXT_texture3D
GL_EXT_texture_array
GL_EXT_texture_buffer_object
GL_EXT_texture_compression_bptc
GL_EXT_texture_compression_latc
GL_EXT_texture_compression_rgtc
GL_EXT_texture_compression_s3tc
GL_EXT_texture_cube_map
GL_EXT_texture_edge_clamp
GL_EXT_texture_env_add
GL_EXT_texture_env_combine
GL_EXT_texture_env_dot3
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_integer
GL_EXT_texture_lod
GL_EXT_texture_lod_bias
GL_EXT_texture_mirror_clamp
GL_EXT_texture_object
GL_EXT_texture_rectangle
GL_EXT_texture_sRGB
GL_EXT_texture_sRGB_decode
GL_EXT_texture_shared_exponent
GL_EXT_texture_snorm
GL_EXT_texture_storage
GL_EXT_texture_swizzle
GL_EXT_timer_query
GL_EXT_transform_feedback
GL_EXT_vertex_array
GL_EXT_vertex_array_bgra
GL_EXT_vertex_attrib_64bit
GL_IBM_texture_mirrored_repeat
GL_KHR_context_flush_control
GL_KHR_debug
GL_KHR_no_error
GL_KHR_parallel_shader_compile
GL_KHR_robust_buffer_access_behavior
GL_KHR_robustness
GL_KTX_buffer_region
GL_NV_alpha_to_coverage_dither_control
GL_NV_blend_square
GL_NV_conditional_render
GL_NV_copy_depth_to_color
GL_NV_copy_image
GL_NV_depth_buffer_float
GL_NV_explicit_multisample
GL_NV_float_buffer
GL_NV_half_float
GL_NV_primitive_restart
GL_NV_texgen_reflection
GL_NV_texture_barrier
GL_OES_EGL_image
GL_SGIS_generate_mipmap
GL_SGIS_texture_edge_clamp
GL_SGIS_texture_lod
GL_SUN_multi_draw_arrays
GL_WIN_swap_hint
WGL_EXT_swap_control
Implementation Dependent OpenGL Limits:
Maximum Fixed Function Texture Units: 8
Maximum DrawElements Vertices: 536870911
Maximum DrawElements Indices: 536870911
GLSL:
Maximum Varying Floats: 128
Maximum Vertex Attributes: 29
Maximum Vertex Uniform Components: 16384
Maximum Fragment Uniform Components: 16384
Maximum Vertex Image Units: 32
Maximum Fragment Image Units: 32
Maximum Pipeline Image Units: 160
Cycles:
CPU device capabilities: SSE2 SSE3 SSE41 AVX AVX2
OpenCL device capabilities:
Number of platforms: 1
Platform #0
Platform Name: AMD Accelerated Parallel Processing
Platform Vendor: Advanced Micro Devices, Inc.
Platform Version: OpenCL 2.1 AMD-APP (2686.5)
Platform Profile: FULL_PROFILE
Platform Extensions: cl_khr_icd cl_khr_d3d10_sharing cl_khr_d3d11_sharing cl_khr_dx9_media_sharing cl_amd_event_callback cl_amd_offline_devices
Number of devices: 1
		Device: #0
			Device Name: gfx804
			Device Board Name: Radeon 550 Series
			Device Vendor: Advanced Micro Devices, Inc.
			Device OpenCL C Version: OpenCL C 2.0
			Device Profile: FULL_PROFILE
			Device Version: OpenCL 2.0 AMD-APP (2686.5)
			Device Extensions: cl_khr_fp64 cl_amd_fp64 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_fp16 cl_khr_gl_sharing cl_khr_gl_depth_images cl_amd_device_attribute_query cl_amd_vec3 cl_amd_printf cl_amd_media_ops cl_amd_media_ops2 cl_amd_popcnt cl_khr_d3d10_sharing cl_khr_d3d11_sharing cl_khr_dx9_media_sharing cl_khr_image2d_from_buffer cl_khr_spir cl_khr_subgroups cl_khr_gl_event cl_khr_depth_images cl_khr_mipmap_image cl_khr_mipmap_image_writes cl_amd_liquid_flash cl_amd_planar_yuv
Enabled add-ons:
io_scene_3ds (version: UNKNOWN, path: C:\Program Files\Blender Foundation\Blender\2.79\scripts\addons\io_scene_3ds\init__.py)
io_scene_fbx (version: (3, 7, 17), path: C:\Program Files\Blender Foundation\Blender\2.79\scripts\addons\io_scene_fbx\
init.py)
io_anim_bvh (version: UNKNOWN, path: C:\Program Files\Blender Foundation\Blender\2.79\scripts\addons\io_anim_bvh\
init.py)
io_mesh_ply (version: UNKNOWN, path: C:\Program Files\Blender Foundation\Blender\2.79\scripts\addons\io_mesh_ply\
init.py)
io_scene_obj (version: (2, 3, 6), path: C:\Program Files\Blender Foundation\Blender\2.79\scripts\addons\io_scene_obj\
init.py)
io_scene_x3d (version: (1, 2, 0), path: C:\Program Files\Blender Foundation\Blender\2.79\scripts\addons\io_scene_x3d\
init.py)
io_mesh_stl (version: (1, 1, 2), path: C:\Program Files\Blender Foundation\Blender\2.79\scripts\addons\io_mesh_stl\
init.py)
io_mesh_uv_layout (version: (1, 1, 1), path: C:\Program Files\Blender Foundation\Blender\2.79\scripts\addons\io_mesh_uv_layout\
init.py)
io_curve_svg (version: UNKNOWN, path: C:\Program Files\Blender Foundation\Blender\2.79\scripts\addons\io_curve_svg\
init.py)
cycles (version: UNKNOWN, path: C:\Program Files\Blender Foundation\Blender\2.79\scripts\addons\cycles\
init__.py)
uv_squares (version: (1, 5, 0), path: C:\Users\Windows\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\uv_squares.py)
Broken: 2.79b Date:2018-03-22 14:10 Hash f4dc9f9d68b
Worked: Last Week
When working on a particular file, since its been the only one I have been working on in a while. When Working in edit mode, my computer will freeze and then move to the Blue Screen of Death. I have ran cleanups and scans. The only time It happens is when working on this file. Haven't had an issue BSOD as long as I don't load this file into blender.
  1. Load File
  2. Select Building
  3. TAB for edit mode. edit a little bit until computer crashes.
Just opened the file and did editing for over 30 minutes. I guess the cleanups helped. Or maybe it was because Firefox (Which seems to be using a hell of lot more memory than it use to) and Blender where open at the same time. I will test this out and see what happens.
Bugs need reproducible steps. likely driver / OS related.
Closing.
