Select box in Sculpt Mode - Grease Pencil Object. #58986
Closed
opened 2018-12-08 00:25:24 +01:00 by Lenon dos Santos Costa Bastos · 14 comments
I am trying to use select box after use a smooth tool...
Thanks.
Operating system:
Graphics card:
Broken:
(example: 2.79b release)
(example: 2.80, edbf15d3c0, blender2.8, 2018-11-28, as found on the splash screen)
I am trying to use select box after use a smooth tool... Thanks. **System Information** Operating system: Graphics card: **Blender Version** Broken: (example: 2.79b release) (example: 2.80, edbf15d3c044, blender2.8, 2018-11-28, as found on the splash screen) Worked: (optional) **Short description of error** **Exact steps for others to reproduce the error** Based on the default startup or an attached .blend file (as simple as possible).
Added subscriber: @Lenon_Bastos
#59547 was marked as duplicate of this issue
Added subscriber: @ZedDB
Antonio Vazquez was assigned by Sebastian Parborg 2018-12-10 14:55:30 +01:00
  1. Add GP monkey
  2. Go into sculpt mode
  3. Try to use the box select tool
  4. The box select tool is not working, instead you are still using a sculpt tool
1. Add GP monkey 2. Go into sculpt mode 3. Try to use the box select tool 4. The box select tool is not working, instead you are still using a sculpt tool
Antonio Vazquez removed their assignment 2018-12-10 19:20:37 +01:00
Campbell Barton was assigned by Antonio Vazquez 2018-12-10 19:20:37 +01:00
Added subscribers: @ideasman42, @antoniov
@ideasman42 Could you take a look of this because you know how works Toolbar?
Added subscriber: @lichtwerk
@lichtwerk Since yesterday or the day before, I cannot change the priority of the tasks.
I get access denied error. Is this by policy change (only bf developers can do that) or is a mistake in the last update?
@lichtwerk Since yesterday or the day before, I cannot change the priority of the tasks. I get access denied error. Is this by policy change (only bf developers can do that) or is a mistake in the last update?
@lichtwerk Don't worry about access denied error, Sergey just fixed the problem.
Added subscriber: @heini
Added subscriber: @Vyach
Worked with pencil. It seems selection exist but invisible
2019-03-02_17-04-13.mp4
Worked with pencil. It seems selection exist but invisible [2019-03-02_17-04-13.mp4](https://archive.blender.org/developer/F6745255/2019-03-02_17-04-13.mp4)
Campbell Barton was unassigned by Dalai Felinto 2019-12-23 16:35:43 +01:00
Member
Philipp Oeser self-assigned this 2020-02-06 17:04:18 +01:00
Member
This should be long resolved (no more select tools outside editmode), if there are any more issue, please open a new report, thx.
(Sorry this has been lying around for so long...)
This should be long resolved (no more select tools outside editmode), if there are any more issue, please open a new report, thx. (Sorry this has been lying around for so long...)
6 Participants
Reference: blender/blender#58986
