No alpha in viewport #59105
Reference: blender/blender#59105
Operating system: win 10
Graphics card: Geforce GT 530
Broken: 2.80 2018-12-10
(example: 2.79b release)
(example: 2.80,
edbf15d3c0
, blender2.8, 2018-11-28, as found on the splash screen)Worked: (optional)
Alpha transparency in bitmaps does not render in viewport in "lookdev" mode. When renderer is set to Cycles, nothing can be done to turn on transparency in viewport. One have to switch to Eevee renderer, then select each material with alpha bitmap transparency and then select settings>blendmode>alpha blend to turn on transparency and then shift back to Cycles renderer to make it work.
Added subscriber: @ToreBahnson
Added subscriber: @ZedDB
I can confirm that cycles is missing the Blend Mode under the material settings panel.
I've create a minimal blender file just to demonstrate the issue: alpha_mode.blend
Just switch to cycles and you can't set the blend mode anymore.
The change EEVEE settings (which also affect LookDev) you need to enable the EEVEE render engine currently. This is weak, but is not considered a bug at the moment, rather a UI thing to improve once.
