Quick Explode is broken in 2.8
Operating system: macOS
Graphics card: Something from Intel.
Broken: 2.80 e4153946ad1e81c697b8d51d92a3e2f088d0af4d, blender2.8, 2018-12-11
Open Blender, press F3, type quick explode, then press enter. Python error about name being required.
Solution
The following change in release/scripts/startup/bl_operators/object_quick_effects.py fixes the initial error:
             if self.fade:
                 explode.show_dead = False
-                uv = obj.data.uv_layers.new("Explode fade")
+                uv = obj.data.uv_layers.new(name="Explode fade")
                 explode.particle_uv = uv.name
But, then there are material errors; the old addon changed the old-style materials. Lines like this:
mat.use_transparency = True
mat.use_transparent_shadows = True
mat.alpha = 0.0
mat.specular_alpha = 0.0
I'm not familiar enough with the new materials in Python to fix that.
PS: macOS 2.8 build was outdated, so using my own build.
