FBX Custom property error #59202
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
5 Participants
Reference: blender/blender-addons#59202
DxDiag.txt
Broken:
2.79.6 hash:642c315bae1
2.8 hash:d415b5c7b85
When I set any custom properties to an object, export the object to FBX, then import it back, on the imported model I get an error message when I wanna edit, add or delete custom properties.
More description
untitled_binary.fbx untitled_ascii.fbx
I tried to create a box with the same property in 3ds Max...I imported similar box with the same property from Blender...in Max exported both boxes into ASCII and Binary fbx (ASCII property closeup in picture below). Then I imported the Binary version into Blender...box with property from Max is editable and Box from Blender is not.
Am I doing something wrong or is it a bug?
Thank you
Added subscriber: @skywalger
Added subscribers: @mont29, @BlenderFreak
@mont29 Hi Bastien, I can confirm this as a bug in latest stable 2.79, nightly 2.79 and 2.8 versions, and it looks like the _RNA_UI property is not serialized to a dictionary?
Custom property errorto FBX Custom property errorAdded subscriber: @lichtwerk
Can also confirm.
on export
fbx_data_element_custom_properties(props, bid)
will include_RNA_UI
and possibly other rna props...(which probably should be exluded).
Will have a look...
This issue was referenced by
e4f4053de6
@lichtwerk exporting _RNA_UI indeed sounds bad, I think a good thing to do would be to skip all props which name starts with
_
(this is common convention in python to mark as 'private', think it would make sense to never export those)?Changed status from 'Open' to: 'Resolved'
@lichtwerk Hi Philipp, can I ask you, will this be propagated also to 2.79 nightly build?
@BlenderFreak: Done (see
3a264229d2
