Dead particles not included in render (F12), but visible in viewport #59272
13 Participants
Reference: blender/blender#59272
Operating system: macOS 10.14 Mojave
Graphics card:
Broken: 2.80,
9c5d104224
, blender2.8, 2018-12-12Worked: 2.79
Dead Particles that are properly rendered in the viewport are not being rendered using F12. This Bug occurs with Eevee, Workbench and Cycles render engines.
Added subscriber: @enie
Added subscriber: @lichtwerk
Confirmed, checking...
#59272.blend
Hm,
make_duplis_particle_system()
seems to be making duplis for dead particles inDAG_EVAL_RENDER
as well asDAG_EVAL_VIEWPORT
...Not sure yet why these are not actually rendered, needs further investigation...
Added subscriber: @486213975.ali
I still have same problem. Pls tell ıf there is any progress..
Added subscriber: @BacMan12
Also encountered this today. Would be nice with a fix but particle nodes is coming, so it will probably be fixed then...hopefully.
Added subscriber: @Jeroen-Bakker
Seems depsgraph related.
When rendering the particles that aren't born are already visible
In viewport the particles that are dead are still visible.
Added subscriber: @GravityDefyingSpaceLizards
The dead particles are being re-spawned on the emitter as they die. I did some trouble-shooting on this, comparing 2.79 to my current version. I'm currently using 2.81.16. .
I created the setup as described in the above original post in 2.79. All works properly.
I then saved the scene and reopened it in 2.81. It still rendered correctly.
I then created an identical particle system in 2.81 next to the imported 2.79 system. The 2.79 particles rendered ok, but the 2.81 particles did not.
If I change the 2.81 emitter to the 2.79 particle setting, it still does not render correctly.
If I change the 2.79 emitter to the 2.81 particle setting it still renders correctly.
I tried breaking the 2.79 particle emitter, and the only way I could do it was to change the number of particles emitted. Then it will not render properly, Undoing the change will correct the render.
Added subscriber: @edferr
great work, had the same problem. precisely the issue, i can only add a work-around, more of a kludge. for still images at least you can "convert to mesh". i used it for a metaball particle soup and it worked, haha. thanks again.
Added subscriber: @ArtturiMantysaari
I am also having this bug in Blender version 2.83
This issue was referenced by
b8b60e132d
Added subscriber: @BeratTurkbikmaz
Arrow Rain Test.blend
I struggling this issue. I tried in 2.83.7 and 2.90.1. But result is the same. This attached project is almost similar to which I want to create an arrow rain scene. Dead particles still not showing in the render.
Added subscriber: @RMENON
I encountered this issue today in 2.90
Encountered what i believe to be the same issue in 3.6.4
On further examination, there was merely a discrepancy between viewport and render, somehow caused by a low cache step size. This may be something worth looking into.
In the file in question, I have an emitter several thousand units above the killer platform.
