UVWarp modifier does not work properly #59330
2 Participants
Reference: blender/blender#59330
Operating system: Windows 10
Graphics card: Nvidia
Broken: UVWarp modifier does not work properly
(example: 2.79b release)
(example: 2.80,
edbf15d3c0
, blender2.8, 2018-11-28, as found on the splash screen)Worked: (optional)
I have attached the blend file here.
http://sodasi.com/robot-bug.blend
As you can see if you move the bone the mapping is very wrong no matter how you change uv axis. I really hope I'm not going to waste your time, but I spend 1 week trying to figure out what to do, so I made sure the uv is not mirrored on both objects, I used any combination possible for uv mapping.. but nothing so far..
Steps to reproduce
8 add a UVWarp modifier -> setup armature to these bones
10 Result. The mapping is very very very very wrong
Expected result -> when you move the target bone, the mapping should be correct
Added subscriber: @iulian.flester
I forgot to mention that I'm following this tutorial
https://www.youtube.com/watch?v=5NlvgMYZgaY&list=PLda3VoSoc_TR7X7wfblBGiRz-bvhKpGkS&index=63
And this is the mouth image
https://www.dropbox.com/s/knjoc3jfd0m1gel/mouths-layout-16.png?dl=0 ]]
Added subscriber: @ZedDB
This is not an issue with 2.8. The same thing happens in 2.79. You simply tried to map the wrong axis to the UV moment.
In the tutorial he mapped the image on the global XZ plane while you tried to do the same but in the YZ plane (and thus the settings can not be the same for it to work)
I have attached a file where I simply rotated the plane and now it works: robot-bug_fixed.blend
So you are saying that in order this to work it has to be oriented in a specific way .... This sound to me like a bug: I never said is 2,8 issue. It replicates to 2,8 and 2,7X as you sa said. So I think there should be a solution for this to work, like maybe add -X, -Y and -Z ... I don't know, but the way is now is very very confusing. I guess just multiplying by -1 on x,y,z should do the trick and offer alot more options.
Thank you very much for taking time to respond to my bug.
Happy Christmass
The bones you are using has to have a specific orientation, yes. You are actually not using the global axis but the local bone axis. For bones the Y axis is following the direction of the bone.
Which is why in the tutorial you mapped the U coordinate to the X axis and the V coordinate to the Y axis.
So if you want to use some other orientation, you simply rotate the bones until they point in the correct way for that view.
