Left in the dark #59361
2 Participants
Reference: blender/blender#59361
Operating system:windows 10 pro 32 bit
Graphics card:ati radeon 3000
Broken:
(example: 2.79b release)
(example: 2.80,
edbf15d3c0
, blender2.8, 2018-11-28, as found on the splash screen)Worked: (optional)blender-2.80.0-git.aca13040dac-windows32
does not start, no message give even if starting it with console and as admin...?
download and run (on my system)
Basically
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0066.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0066.frag
GPUShader: compile error:
shader string 1
1 #version 330
shader string 2
shader string 3
2 #define GPU_ATI
shader string 4
bla bla bla
388 #endif
389
390 fragColor = vec4(shaded_color, 1.0);
391 }
Fragment shader failed to compile with the following errors:
WARNING: 4:88: warning(#283) Implicit cast from int to uint
ERROR: 4:88: error(#160) Cannot convert from 'unsigned int' to 'mediump int'
ERROR: error(#273) 1 compilation errors. No code generated
whole transcript follows
F:\DesktopEverywhere\blender-2.80.0-git.aca13040dac-windows32>blender --debug-all
Switching to fully guarded memory allocator.
read file
DEG::
anonymous-namespace'::deg_graph_id_tag_update: id=SCScene flags=LEGACY_0 AL lib: (EE) UpdateDeviceParams: Failed to set 48000hz, got 44100hz instead ED_screen_refresh: set screen DEG::
anonymous-namespace'::deg_graph_id_tag_update: id=SCScene flags=COPY_ON_WRITEDEG::
anonymous-namespace'::deg_graph_id_tag_update: id=OBCube flags=TRANSFORM, GEOMETRY, COPY_ON_WRITE DEG::
anonymous-namespace'::deg_graph_id_tag_update: id=MECube flags=LEGACY_0DEG::
anonymous-namespace'::deg_graph_id_tag_update: id=MAMaterial flags=COPY_ON_WRITE DEG::
anonymous-namespace'::deg_graph_id_tag_update: id=NTShader Nodetree flags=COPY_ON_WRITEDEG::
anonymous-namespace'::deg_graph_id_tag_update: id=NTShader Nodetree flags=COPY_ON_WRITE DEG::
anonymous-namespace'::deg_graph_id_tag_update: id=MECube flags=COPY_ON_WRITEDEG::
anonymous-namespace'::deg_graph_id_tag_update: id=OBLight flags=TRANSFORM, GEOMETRY, COPY_ON_WRITE DEG::
anonymous-namespace'::deg_graph_id_tag_update: id=LALight flags=COPY_ON_WRITEDEG::
anonymous-namespace'::deg_graph_id_tag_update: id=OBCamera flags=TRANSFORM, GEOMETRY, COPY_ON_WRITE DEG::
anonymous-namespace'::deg_graph_id_tag_update: id=CACamera flags=COPY_ON_WRITEDEG::
anonymous-namespace'::deg_graph_id_tag_update: id=GRMaster Collection flags=COPY_ON_WRITE DEG::
anonymous-namespace'::deg_graph_id_tag_update: id=GRCollection flags=COPY_ON_WRITEDEG::
anonymous-namespace'::deg_graph_id_tag_update: id=WOWorld flags=COPY_ON_WRITE DEG::
anonymous-namespace'::deg_graph_id_tag_update: id=GRCollection flags=COPY_ON_WRITEDEG::`anonymous-namespace'::deg_graph_id_tag_update: id=WOWorld flags=COPY_ON_WRITE
Depsgraph built in 0.178116 seconds.
[SCScene :: View Layer]: Operation is entry point for update: COPY_ON_WRITE()
[SCScene :: View Layer]: Operation is entry point for update: PLACEHOLDER(Eval Init)
[SCScene :: View Layer]: Operation is entry point for update: GEOMETRY_SELECT_UPDATE()
[SCScene :: View Layer]: Operation is entry point for update: TRANSFORM_OBJECT_UBEREVAL()
[SCScene :: View Layer]: Operation is entry point for update: PLACEHOLDER(Eval Done)
[SCScene :: View Layer]: Operation is entry point for update: TRANSFORM_LOCAL()
[SCScene :: View Layer]: Operation is entry point for update: PLACEHOLDER(Scene Eval)
[SCScene :: View Layer]: Operation is entry point for update: PARAMETERS_EVAL()
[SCScene :: View Layer]: Operation is entry point for update: TRANSFORM_FINAL()
[SCScene :: View Layer]: Operation is entry point for update: VIEW_LAYER_EVAL()
[SCScene :: View Layer]: Operation is entry point for update: GEOMETRY_UBEREVAL()
[SCScene :: View Layer]: Operation is entry point for update: PLACEHOLDER(Geometry Eval)
[SCScene :: View Layer]: Accumulated recalc bits for SCScene: 128
[SCScene :: View Layer]: Accumulated recalc bits for OBCube: 387
[SCScene :: View Layer]: Accumulated recalc bits for MAMaterial: 384
[SCScene :: View Layer]: Accumulated recalc bits for NTShader Nodetree: 128
[SCScene :: View Layer]: Accumulated recalc bits for MECube: 4294967171
[SCScene :: View Layer]: Accumulated recalc bits for OBLight: 131
[SCScene :: View Layer]: Accumulated recalc bits for LALight: 128
[SCScene :: View Layer]: Accumulated recalc bits for OBCamera: 131
[SCScene :: View Layer]: Accumulated recalc bits for CACamera: 128
[SCScene :: View Layer]: Accumulated recalc bits for GRMaster Collection: 128
[SCScene :: View Layer]: Accumulated recalc bits for GRCollection: 128
[SCScene :: View Layer]: Accumulated recalc bits for WOWorld: 128
[SCScene :: View Layer]: DEG::deg_evaluate_copy_on_write on WOWorld (08F7C840)
[SCScene :: View Layer]: DEG::deg_evaluate_copy_on_write on GRCollection (08F02190)
[SCScene :: View Layer]: DEG::deg_evaluate_copy_on_write on GRMaster Collection (08F00930)
[SCScene :: View Layer]: DEG::deg_evaluate_copy_on_write on CACamera (08F5D2E0)
[SCScene :: View Layer]: DEG::deg_evaluate_copy_on_write on LALight (08F36458)
[SCScene :: View Layer]: DEG::deg_evaluate_copy_on_write on MECube (090D7210)
[SCScene :: View Layer]: DEG::deg_evaluate_copy_on_write on OBCamera (090D7C50)
[SCScene :: View Layer]: DEG::deg_evaluate_copy_on_write on OBLight (090D7790)
[SCScene :: View Layer]: DEG::deg_evaluate_copy_on_write on OBCube (08F5CC90)
[SCScene :: View Layer]: DEG::deg_evaluate_copy_on_write on NTShader Nodetree (08F5D150)
[SCScene :: View Layer]: DEG::deg_evaluate_copy_on_write on SCScene (08FD14A8)
[SCScene :: View Layer]: DEG::deg_evaluate_copy_on_write on MAMaterial (08FEC5F0)
[SCScene :: View Layer]: BKE_layer_eval_view_layer on View Layer (0C760020)
[SCScene :: View Layer]: BKE_object_eval_local_transform on OBLight (090D7790)
[SCScene :: View Layer]: BKE_object_eval_local_transform on OBCamera (090D7C50)
[SCScene :: View Layer]: BKE_object_eval_flush_base_flags on OBCube (08F5CC90)
[SCScene :: View Layer]: BKE_object_eval_transform_final on OBLight (090D7790)
[SCScene :: View Layer]: BKE_object_eval_transform_final on OBCamera (090D7C50)
[SCScene :: View Layer]: BKE_object_eval_flush_base_flags on OBCamera (090D7C50)
[SCScene :: View Layer]: BKE_object_eval_flush_base_flags on OBLight (090D7790)
[SCScene :: View Layer]: BKE_object_data_select_update on MECube (090D7210)
[SCScene :: View Layer]: BKE_mesh_eval_geometry on MECube (090D7210)
[SCScene :: View Layer]: BKE_material_eval on MAMaterial (08FEC5F0)
[SCScene :: View Layer]: BKE_object_eval_local_transform on OBCube (08F5CC90)
[SCScene :: View Layer]: BKE_object_eval_uber_data on OBCube (08F5CC90)
[SCScene :: View Layer]: BKE_object_eval_transform_final on OBCube (08F5CC90)
[SCScene :: View Layer]: BKE_object_handle_data_update on OBCube (08F5CC90)
[SCScene :: View Layer]: BKE_object_eval_update_shading on OBCube (08F5CC90)
Depsgraph updated in 0.083674 seconds.
found bundled python: F:\DesktopEverywhere\blender-2.80.0-git.aca13040dac-windows32\2.80\python
time bl_operators 0.1929
time bl_ui 0.6596
time keyingsets_builtins 0.0141
time nodeitems_builtins 0.0176
bl_app_template_utils.reset('')
I1214 12:17:25.350327 2656 blender_python.cpp:189] Debug flags initialized to:
CPU flags:
CUDA flags:
Adaptive Compile: False
OpenCL flags:
Python Script Load Time 1.2767
Warning, unregistered class: Import3DS(Operator)
Warning, unregistered class: Export3DS(Operator)
Warning, unregistered class: ImportX3D(Operator)
Warning, unregistered class: ExportX3D(Operator)
Warning, unregistered class: PresetMenu(Panel)
Warning, unregistered class: PARTICLE_PT_render_billboards_alignment(Panel)
Warning, unregistered class: VIEW3D_PT_tools_grease_pencil_edit(Panel)
Warning, unregistered class: CYCLES_RENDER_PT_sampling_total(Panel)
Warning, unregistered class: MASK_MT_add(Menu)
loading preset: F:\DesktopEverywhere\blender-2.80.0-git.aca13040dac-windows32\2.80\scripts\presets\keyconfig\blender.py
FRS_set_context: context 0x05542C10 scene 0x08FF0AA0
UI_menutype_draw: opening menu "WM_MT_splash"
ghost_event_proc: window 1 state = normal
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0001.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0001.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0001.geom
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0002.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0002.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0003.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0003.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0004.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0004.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0005.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0005.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0006.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0006.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0007.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0007.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0008.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0008.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0009.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0009.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0010.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0010.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0010.geom
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0011.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0011.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0011.geom
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0012.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0012.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0012.geom
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0013.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0013.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0013.geom
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0014.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0014.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0014.geom
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0015.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0015.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0015.geom
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0016.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0016.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0017.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0017.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0018.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0018.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0019.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0019.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0020.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0020.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0020.geom
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0021.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0021.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0022.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0022.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0022.geom
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0023.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0023.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0024.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0024.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0024.geom
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0025.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0025.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0026.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0026.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0027.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0027.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0028.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0028.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0029.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0029.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0030.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0030.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0031.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0031.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0032.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0032.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0033.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0033.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0034.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0034.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0035.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0035.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0036.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0036.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0037.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0037.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0038.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0038.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0039.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0039.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0039.geom
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0040.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0040.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0040.geom
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0041.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0041.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0041.geom
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0042.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0042.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0043.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0043.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0044.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0044.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0045.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0045.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0046.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0046.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0047.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0047.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0048.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0048.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0049.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0049.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0050.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0050.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0051.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0051.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0052.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0052.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0053.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0053.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0054.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0054.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0055.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0055.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0056.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0056.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0057.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0057.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0058.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0058.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0059.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0059.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0060.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0060.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0061.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0061.frag
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0062.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0062.frag
shader string 1
1 #version 330
shader string 2
shader string 3
2 #define GPU_ATI
shader string 4
3 #define V3D_SHADING_OBJECT_OUTLINE
4 #define V3D_SHADING_SPECULAR_HIGHLIGHT
5 #define V3D_LIGHTING_STUDIO
6 #define OBJECT_ID_PASS_ENABLED
7 #define MATDATA_PASS_ENABLED
8 #define NORMAL_VIEWPORT_PASS_ENABLED
9 #define WORKBENCH_ENCODE_NORMALS
shader string 5
10 struct LightData {
11 vec4 direction;
12 vec4 specular_color;
13 vec4 diffuse_color_wrap; /* rgb: diffuse col a: wrapped lighting factor /
14 };
15
16 struct WorldData {
17 vec4 background_color_low;
18 vec4 background_color_high;
19 vec4 object_outline_color;
20 vec4 shadow_direction_vs;
21 LightData lights[4];
22 vec4 ambient_color;
23 int num_lights;
24 int matcap_orientation;
25 float background_alpha;
26 float curvature_ridge;
27 float curvature_valley;
28 int pad[3];
29 };
30 #define NO_OBJECT_ID uint(0)
31 #define EPSILON 0.00001
32 #define M_PI 3.14159265358979323846
33
34 #define CAVITY_BUFFER_RANGE 4.0
35
36 / 4x4 bayer matrix prepared for 8bit UNORM precision error. /
37 #define P(x) (((x + 0.5) * (1.0 / 16.0) - 0.5) * (1.0 / 255.0))
38 const vec4 dither_mat4x4- [x] = vec4[4](
39 vec4( P(0.0), P(8.0), P(2.0), P(10.0)),
40 vec4(P(12.0), P(4.0), P(14.0), P(6.0)),
41 vec4( P(3.0), P(11.0), P(1.0), P(9.0)),
42 vec4(P(15.0), P(7.0), P(13.0), P(5.0))
43 );
44
45 float bayer_dither_noise() {
46 ivec2 tx1 = ivec2(gl_FragCoord.xy) % 4;
47 ivec2 tx2 = ivec2(gl_FragCoord.xy) % 2;
48 return dither_mat4x4[tx1.x][tx1.y];
49 }
50
51 #ifdef WORKBENCH_ENCODE_NORMALS
52
53 #define WB_Normal vec2
54
55 / From http://aras-p.info/texts/CompactNormalStorage.html
56 * Using Method #4: Spheremap Transform /
57 vec3 workbench_normal_decode(WB_Normal enc)
58 {
59 vec2 fenc = enc.xy * 4.0 - 2.0;
60 float f = dot(fenc, fenc);
61 float g = sqrt(1.0 - f / 4.0);
62 vec3 n;
63 n.xy = fencg;
64 n.z = 1 - f / 2;
65 return n;
66 }
67
68 /* From http://aras-p.info/texts/CompactNormalStorage.html
69 * Using Method #4: Spheremap Transform /
70 WB_Normal workbench_normal_encode(vec3 n)
71 {
72 float p = sqrt(n.z * 8.0 + 8.0);
73 n.xy = clamp(n.xy / p + 0.5, 0.0, 1.0);
74 return n.xy;
75 }
76
77 #else
78 #define WB_Normal vec3
79 / Well just do nothing... /
80 # define workbench_normal_encode(a) (a)
81 # define workbench_normal_decode(a) (a)
82 #endif / WORKBENCH_ENCODE_NORMALS /
83
84 / Encoding into the alpha of a RGBA8 UNORM texture. /
85 #define TARGET_BITCOUNT 8u
86 #define METALLIC_BITS 3u / Metallic channel is less important. /
87 #define ROUGHNESS_BITS (TARGET_BITCOUNT - METALLIC_BITS)
88 #define TOTAL_BITS (METALLIC_BITS + ROUGHNESS_BITS)
89
90 / Encode 2 float into 1 with the desired precision. /
91 float workbench_float_pair_encode(float v1, float v2)
92 {
93 const uint total_mask = ~(0xFFFFFFFFu << TOTAL_BITS);
94 const uint v1_mask = ~(0xFFFFFFFFu << ROUGHNESS_BITS);
95 const uint v2_mask = ~(0xFFFFFFFFu << METALLIC_BITS);
96 int iv1 = int(v1 * float(v1_mask));
97 int iv2 = int(v2 * float(v2_mask)) << ROUGHNESS_BITS;
98 return float(iv1 | iv2) * (1.0 / float(total_mask));
99 }
100
101 void workbench_float_pair_decode(float data, out float v1, out float v2)
102 {
103 const uint total_mask = ~(0xFFFFFFFFu << TOTAL_BITS);
104 const uint v1_mask = ~(0xFFFFFFFFu << ROUGHNESS_BITS);
105 const uint v2_mask = ~(0xFFFFFFFFu << METALLIC_BITS);
106 uint idata = uint(data * float(total_mask));
107 v1 = float(idata & v1_mask) * (1.0 / float(v1_mask));
108 v2 = float(idata >> ROUGHNESS_BITS) * (1.0 / float(v2_mask));
109 }
110
111 float calculate_transparent_weight(float z, float alpha)
112 {
113 #if 0
114 / Eq 10 : Good for surfaces with varying opacity (like particles) /
115 float a = min(1.0, alpha * 10.0) + 0.01;
116 float b = -gl_FragCoord.z * 0.95 + 1.0;
117 float w = a * a * a * 3e2 * b * b * b;
118 #else
119 / Eq 7 put more emphasis on surfaces closer to the view. /
120 // float w = 10.0 / (1e-5 + pow(abs(z) / 5.0, 2.0) + pow(abs(z) / 200.0, 6.0)); / Eq 7 /
121 // float w = 10.0 / (1e-5 + pow(abs(z) / 10.0, 3.0) + pow(abs(z) / 200.0, 6.0)); / Eq 8 /
122 // float w = 10.0 / (1e-5 + pow(abs(z) / 200.0, 4.0)); / Eq 9 /
123 / Same as eq 7, but optimized. */
124 float a = abs(z) / 5.0;
125 float b = abs(z) / 200.0;
126 b = b;
127 float w = 10.0 / ((1e-5 + a * a) + b * (b * b)); / Eq 7 /
128 #endif
129 return alpha * clamp(w, 1e-2, 3e2);
130 }
131
132 / Special function only to be used with calculate_transparent_weight(). /
133 float linear_zdepth(float depth, vec4 viewvecs- [x], mat4 proj_mat)
134 {
135 if (proj_mat- [x]- [x] == 0.0) {
136 float d = 2.0 * depth - 1.0;
137 return -proj_mat- [x]- [x] / (d + proj_mat- [x][2]);
138 }
139 else {
140 / Return depth from near plane. /
141 return depth * viewvecs- [x].z;
142 }
143 }
144
145 vec3 view_vector_from_screen_uv(vec2 uv, vec4 viewvecs- [x], mat4 proj_mat)
146 {
147 return (proj_mat- [x]- [x] == 0.0)
148 ? normalize(viewvecs- [x].xyz + vec3(uv, 0.0) * viewvecs- [x].xyz)
149 : vec3(0.0, 0.0, 1.0);
150 }
151
152 vec2 matcap_uv_compute(vec3 I, vec3 N, bool flipped)
153 {
154 / Quick creation of an orthonormal basis /
155 float a = 1.0 / (1.0 + I.z);
156 float b = -I.x * I.y * a;
157 vec3 b1 = vec3(1.0 - I.x * I.x * a, b, -I.x);
158 vec3 b2 = vec3(b, 1.0 - I.y * I.y * a, -I.y);
159 vec2 matcap_uv = vec2(dot(b1, N), dot(b2, N));
160 if (flipped) {
161 matcap_uv.x = -matcap_uv.x;
162 }
163 return matcap_uv * 0.496 + 0.5;
164 }
165 uniform int object_id = 0;
166
167 uniform vec3 materialDiffuseColor;
168 uniform float materialMetallic;
169 uniform float materialRoughness;
170
171 uniform sampler2D image;
172 uniform float ImageTransparencyCutoff = 0.1;
173
174 #ifdef NORMAL_VIEWPORT_PASS_ENABLED
175 in vec3 normal_viewport;
176 #endif
177
178 #ifdef V3D_SHADING_TEXTURE_COLOR
179 in vec2 uv_interp;
180 #endif
181
182 #ifdef HAIR_SHADER
183 flat in float hair_rand;
184 #endif
185
186 #ifdef MATDATA_PASS_ENABLED
187 layout(location=0) out vec4 materialData;
188 #endif
189 #ifdef OBJECT_ID_PASS_ENABLED
190 layout(location=1) out uint objectId;
191 #endif
192 #ifdef NORMAL_VIEWPORT_PASS_ENABLED
193 layout(location=2) out WB_Normal normalViewport;
194 #endif
195
196 void main()
197 {
198 #ifdef MATDATA_PASS_ENABLED
199 float metallic, roughness;
200 vec4 color;
201
202 # ifdef V3D_SHADING_TEXTURE_COLOR
203 color = texture(image, uv_interp);
204 if (color.a < ImageTransparencyCutoff) {
205 discard;
206 }
207 # else
208 color.rgb = materialDiffuseColor;
209 # endif
210
211 # ifdef V3D_LIGHTING_MATCAP
212 / Encode front facing in metallic channel. /
213 metallic = float(gl_FrontFacing);
214 roughness = 0.0;
215 # else
216 metallic = materialMetallic;
217 roughness = materialRoughness;
218 # endif
219
220 # ifdef HAIR_SHADER
221 / Add some variation to the hairs to avoid uniform look. /
222 float hair_variation = hair_rand * 0.1;
223 color = clamp(color - hair_variation, 0.0, 1.0);
224 metallic = clamp(materialMetallic - hair_variation, 0.0, 1.0);
225 roughness = clamp(materialRoughness - hair_variation, 0.0, 1.0);
226 # endif
227
228 materialData.rgb = color.rgb;
229 materialData.a = workbench_float_pair_encode(roughness, metallic);
230 #endif / MATDATA_PASS_ENABLED */
231
232 #ifdef OBJECT_ID_PASS_ENABLED
233 objectId = uint(object_id);
234 #endif
235
236 #ifdef NORMAL_VIEWPORT_PASS_ENABLED
237 vec3 n = (gl_FrontFacing) ? normal_viewport : -normal_viewport;
238 n = normalize(n);
239 normalViewport = workbench_normal_encode(n);
240 #endif
241 }
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0063.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0063.frag
shader string 1
1 #version 330
shader string 2
shader string 3
2 #define GPU_ATI
shader string 4
10 #define HAIR_SHADER
shader string 5
11 struct LightData {
12 vec4 direction;
13 vec4 specular_color;
14 vec4 diffuse_color_wrap; /* rgb: diffuse col a: wrapped lighting factor /
15 };
16
17 struct WorldData {
18 vec4 background_color_low;
19 vec4 background_color_high;
20 vec4 object_outline_color;
21 vec4 shadow_direction_vs;
22 LightData lights[4];
23 vec4 ambient_color;
24 int num_lights;
25 int matcap_orientation;
26 float background_alpha;
27 float curvature_ridge;
28 float curvature_valley;
29 int pad[3];
30 };
31 #define NO_OBJECT_ID uint(0)
32 #define EPSILON 0.00001
33 #define M_PI 3.14159265358979323846
34
35 #define CAVITY_BUFFER_RANGE 4.0
36
37 / 4x4 bayer matrix prepared for 8bit UNORM precision error. /
38 #define P(x) (((x + 0.5) * (1.0 / 16.0) - 0.5) * (1.0 / 255.0))
39 const vec4 dither_mat4x4- [x] = vec4[4](
40 vec4( P(0.0), P(8.0), P(2.0), P(10.0)),
41 vec4(P(12.0), P(4.0), P(14.0), P(6.0)),
42 vec4( P(3.0), P(11.0), P(1.0), P(9.0)),
43 vec4(P(15.0), P(7.0), P(13.0), P(5.0))
44 );
45
46 float bayer_dither_noise() {
47 ivec2 tx1 = ivec2(gl_FragCoord.xy) % 4;
48 ivec2 tx2 = ivec2(gl_FragCoord.xy) % 2;
49 return dither_mat4x4[tx1.x][tx1.y];
50 }
51
52 #ifdef WORKBENCH_ENCODE_NORMALS
53
54 #define WB_Normal vec2
55
56 / From http://aras-p.info/texts/CompactNormalStorage.html
57 * Using Method #4: Spheremap Transform /
58 vec3 workbench_normal_decode(WB_Normal enc)
59 {
60 vec2 fenc = enc.xy * 4.0 - 2.0;
61 float f = dot(fenc, fenc);
62 float g = sqrt(1.0 - f / 4.0);
63 vec3 n;
64 n.xy = fencg;
65 n.z = 1 - f / 2;
66 return n;
67 }
68
69 /* From http://aras-p.info/texts/CompactNormalStorage.html
70 * Using Method #4: Spheremap Transform /
71 WB_Normal workbench_normal_encode(vec3 n)
72 {
73 float p = sqrt(n.z * 8.0 + 8.0);
74 n.xy = clamp(n.xy / p + 0.5, 0.0, 1.0);
75 return n.xy;
76 }
77
78 #else
79 #define WB_Normal vec3
80 / Well just do nothing... /
81 # define workbench_normal_encode(a) (a)
82 # define workbench_normal_decode(a) (a)
83 #endif / WORKBENCH_ENCODE_NORMALS /
84
85 / Encoding into the alpha of a RGBA8 UNORM texture. /
86 #define TARGET_BITCOUNT 8u
87 #define METALLIC_BITS 3u / Metallic channel is less important. /
88 #define ROUGHNESS_BITS (TARGET_BITCOUNT - METALLIC_BITS)
89 #define TOTAL_BITS (METALLIC_BITS + ROUGHNESS_BITS)
90
91 / Encode 2 float into 1 with the desired precision. /
92 float workbench_float_pair_encode(float v1, float v2)
93 {
94 const uint total_mask = ~(0xFFFFFFFFu << TOTAL_BITS);
95 const uint v1_mask = ~(0xFFFFFFFFu << ROUGHNESS_BITS);
96 const uint v2_mask = ~(0xFFFFFFFFu << METALLIC_BITS);
97 int iv1 = int(v1 * float(v1_mask));
98 int iv2 = int(v2 * float(v2_mask)) << ROUGHNESS_BITS;
99 return float(iv1 | iv2) * (1.0 / float(total_mask));
100 }
101
102 void workbench_float_pair_decode(float data, out float v1, out float v2)
103 {
104 const uint total_mask = ~(0xFFFFFFFFu << TOTAL_BITS);
105 const uint v1_mask = ~(0xFFFFFFFFu << ROUGHNESS_BITS);
106 const uint v2_mask = ~(0xFFFFFFFFu << METALLIC_BITS);
107 uint idata = uint(data * float(total_mask));
108 v1 = float(idata & v1_mask) * (1.0 / float(v1_mask));
109 v2 = float(idata >> ROUGHNESS_BITS) * (1.0 / float(v2_mask));
110 }
111
112 float calculate_transparent_weight(float z, float alpha)
113 {
114 #if 0
115 / Eq 10 : Good for surfaces with varying opacity (like particles) /
116 float a = min(1.0, alpha * 10.0) + 0.01;
117 float b = -gl_FragCoord.z * 0.95 + 1.0;
118 float w = a * a * a * 3e2 * b * b * b;
119 #else
120 / Eq 7 put more emphasis on surfaces closer to the view. /
121 // float w = 10.0 / (1e-5 + pow(abs(z) / 5.0, 2.0) + pow(abs(z) / 200.0, 6.0)); / Eq 7 /
122 // float w = 10.0 / (1e-5 + pow(abs(z) / 10.0, 3.0) + pow(abs(z) / 200.0, 6.0)); / Eq 8 /
123 // float w = 10.0 / (1e-5 + pow(abs(z) / 200.0, 4.0)); / Eq 9 /
124 / Same as eq 7, but optimized. */
125 float a = abs(z) / 5.0;
126 float b = abs(z) / 200.0;
127 b = b;
128 float w = 10.0 / ((1e-5 + a * a) + b * (b * b)); / Eq 7 /
129 #endif
130 return alpha * clamp(w, 1e-2, 3e2);
131 }
132
133 / Special function only to be used with calculate_transparent_weight(). /
134 float linear_zdepth(float depth, vec4 viewvecs- [x], mat4 proj_mat)
135 {
136 if (proj_mat- [x]- [x] == 0.0) {
137 float d = 2.0 * depth - 1.0;
138 return -proj_mat- [x]- [x] / (d + proj_mat- [x][2]);
139 }
140 else {
141 / Return depth from near plane. /
142 return depth * viewvecs- [x].z;
143 }
144 }
145
146 vec3 view_vector_from_screen_uv(vec2 uv, vec4 viewvecs- [x], mat4 proj_mat)
147 {
148 return (proj_mat- [x]- [x] == 0.0)
149 ? normalize(viewvecs- [x].xyz + vec3(uv, 0.0) * viewvecs- [x].xyz)
150 : vec3(0.0, 0.0, 1.0);
151 }
152
153 vec2 matcap_uv_compute(vec3 I, vec3 N, bool flipped)
154 {
155 / Quick creation of an orthonormal basis /
156 float a = 1.0 / (1.0 + I.z);
157 float b = -I.x * I.y * a;
158 vec3 b1 = vec3(1.0 - I.x * I.x * a, b, -I.x);
159 vec3 b2 = vec3(b, 1.0 - I.y * I.y * a, -I.y);
160 vec2 matcap_uv = vec2(dot(b1, N), dot(b2, N));
161 if (flipped) {
162 matcap_uv.x = -matcap_uv.x;
163 }
164 return matcap_uv * 0.496 + 0.5;
165 }
166 uniform int object_id = 0;
167
168 uniform vec3 materialDiffuseColor;
169 uniform float materialMetallic;
170 uniform float materialRoughness;
171
172 uniform sampler2D image;
173 uniform float ImageTransparencyCutoff = 0.1;
174
175 #ifdef NORMAL_VIEWPORT_PASS_ENABLED
176 in vec3 normal_viewport;
177 #endif
178
179 #ifdef V3D_SHADING_TEXTURE_COLOR
180 in vec2 uv_interp;
181 #endif
182
183 #ifdef HAIR_SHADER
184 flat in float hair_rand;
185 #endif
186
187 #ifdef MATDATA_PASS_ENABLED
188 layout(location=0) out vec4 materialData;
189 #endif
190 #ifdef OBJECT_ID_PASS_ENABLED
191 layout(location=1) out uint objectId;
192 #endif
193 #ifdef NORMAL_VIEWPORT_PASS_ENABLED
194 layout(location=2) out WB_Normal normalViewport;
195 #endif
196
197 void main()
198 {
199 #ifdef MATDATA_PASS_ENABLED
200 float metallic, roughness;
201 vec4 color;
202
203 # ifdef V3D_SHADING_TEXTURE_COLOR
204 color = texture(image, uv_interp);
205 if (color.a < ImageTransparencyCutoff) {
206 discard;
207 }
208 # else
209 color.rgb = materialDiffuseColor;
210 # endif
211
212 # ifdef V3D_LIGHTING_MATCAP
213 / Encode front facing in metallic channel. /
214 metallic = float(gl_FrontFacing);
215 roughness = 0.0;
216 # else
217 metallic = materialMetallic;
218 roughness = materialRoughness;
219 # endif
220
221 # ifdef HAIR_SHADER
222 / Add some variation to the hairs to avoid uniform look. /
223 float hair_variation = hair_rand * 0.1;
224 color = clamp(color - hair_variation, 0.0, 1.0);
225 metallic = clamp(materialMetallic - hair_variation, 0.0, 1.0);
226 roughness = clamp(materialRoughness - hair_variation, 0.0, 1.0);
227 # endif
228
229 materialData.rgb = color.rgb;
230 materialData.a = workbench_float_pair_encode(roughness, metallic);
231 #endif / MATDATA_PASS_ENABLED */
232
233 #ifdef OBJECT_ID_PASS_ENABLED
234 objectId = uint(object_id);
235 #endif
236
237 #ifdef NORMAL_VIEWPORT_PASS_ENABLED
238 vec3 n = (gl_FrontFacing) ? normal_viewport : -normal_viewport;
239 n = normalize(n);
240 normalViewport = workbench_normal_encode(n);
241 #endif
242 }
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0064.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0064.frag
shader string 1
1 #version 330
shader string 2
shader string 3
2 #define GPU_ATI
shader string 4
9 #define V3D_SHADING_TEXTURE_COLOR
10 #define WORKBENCH_ENCODE_NORMALS
shader string 5
12 vec4 direction;
15 };
16
24 int num_lights;
29 int pad[3];
30 };
34
36
44 );
45
50 }
51
53
55
59 {
63 vec3 n;
64 n.xy = fencg;
65 n.z = 1 - f / 2;
66 return n;
67 }
68
72 {
75 return n.xy;
76 }
77
78 #else
84
90
93 {
100 }
101
103 {
110 }
111
113 {
114 #if 0
119 #else
127 b = b;
129 #endif
131 }
132
135 {
139 }
140 else {
143 }
144 }
145
147 {
151 }
152
154 {
161 if (flipped) {
163 }
165 }
167
171
174
177 #endif
178
181 #endif
182
185 #endif
186
189 #endif
192 #endif
195 #endif
196
197 void main()
198 {
201 vec4 color;
202
206 discard;
207 }
208 # else
210 # endif
211
216 # else
219 # endif
220
227 # endif
228
232
235 #endif
236
241 #endif
242 }
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0065.vert
Shader file written to disk: C:\Users\ADMINI~1\AppData\Local\Temp\blender_a02656\0065.frag
shader string 1
1 #version 330
shader string 2
shader string 3
2 #define GPU_ATI
shader string 4
11 #define HAIR_SHADER
shader string 5
12 struct LightData {
13 vec4 direction;
14 vec4 specular_color;
15 vec4 diffuse_color_wrap; /* rgb: diffuse col a: wrapped lighting factor /
16 };
17
18 struct WorldData {
19 vec4 background_color_low;
20 vec4 background_color_high;
21 vec4 object_outline_color;
22 vec4 shadow_direction_vs;
23 LightData lights[4];
24 vec4 ambient_color;
25 int num_lights;
26 int matcap_orientation;
27 float background_alpha;
28 float curvature_ridge;
29 float curvature_valley;
30 int pad[3];
31 };
32 #define NO_OBJECT_ID uint(0)
33 #define EPSILON 0.00001
34 #define M_PI 3.14159265358979323846
35
36 #define CAVITY_BUFFER_RANGE 4.0
37
38 / 4x4 bayer matrix prepared for 8bit UNORM precision error. /
39 #define P(x) (((x + 0.5) * (1.0 / 16.0) - 0.5) * (1.0 / 255.0))
40 const vec4 dither_mat4x4- [x] = vec4[4](
41 vec4( P(0.0), P(8.0), P(2.0), P(10.0)),
42 vec4(P(12.0), P(4.0), P(14.0), P(6.0)),
43 vec4( P(3.0), P(11.0), P(1.0), P(9.0)),
44 vec4(P(15.0), P(7.0), P(13.0), P(5.0))
45 );
46
47 float bayer_dither_noise() {
48 ivec2 tx1 = ivec2(gl_FragCoord.xy) % 4;
49 ivec2 tx2 = ivec2(gl_FragCoord.xy) % 2;
50 return dither_mat4x4[tx1.x][tx1.y];
51 }
52
53 #ifdef WORKBENCH_ENCODE_NORMALS
54
55 #define WB_Normal vec2
56
57 / From http://aras-p.info/texts/CompactNormalStorage.html
58 * Using Method #4: Spheremap Transform /
59 vec3 workbench_normal_decode(WB_Normal enc)
60 {
61 vec2 fenc = enc.xy * 4.0 - 2.0;
62 float f = dot(fenc, fenc);
63 float g = sqrt(1.0 - f / 4.0);
64 vec3 n;
65 n.xy = fencg;
66 n.z = 1 - f / 2;
67 return n;
68 }
69
70 /* From http://aras-p.info/texts/CompactNormalStorage.html
71 * Using Method #4: Spheremap Transform /
72 WB_Normal workbench_normal_encode(vec3 n)
73 {
74 float p = sqrt(n.z * 8.0 + 8.0);
75 n.xy = clamp(n.xy / p + 0.5, 0.0, 1.0);
76 return n.xy;
77 }
78
79 #else
80 #define WB_Normal vec3
81 / Well just do nothing... /
82 # define workbench_normal_encode(a) (a)
83 # define workbench_normal_decode(a) (a)
84 #endif / WORKBENCH_ENCODE_NORMALS /
85
86 / Encoding into the alpha of a RGBA8 UNORM texture. /
87 #define TARGET_BITCOUNT 8u
88 #define METALLIC_BITS 3u / Metallic channel is less important. /
89 #define ROUGHNESS_BITS (TARGET_BITCOUNT - METALLIC_BITS)
90 #define TOTAL_BITS (METALLIC_BITS + ROUGHNESS_BITS)
91
92 / Encode 2 float into 1 with the desired precision. /
93 float workbench_float_pair_encode(float v1, float v2)
94 {
95 const uint total_mask = ~(0xFFFFFFFFu << TOTAL_BITS);
96 const uint v1_mask = ~(0xFFFFFFFFu << ROUGHNESS_BITS);
97 const uint v2_mask = ~(0xFFFFFFFFu << METALLIC_BITS);
98 int iv1 = int(v1 * float(v1_mask));
99 int iv2 = int(v2 * float(v2_mask)) << ROUGHNESS_BITS;
100 return float(iv1 | iv2) * (1.0 / float(total_mask));
101 }
102
103 void workbench_float_pair_decode(float data, out float v1, out float v2)
104 {
105 const uint total_mask = ~(0xFFFFFFFFu << TOTAL_BITS);
106 const uint v1_mask = ~(0xFFFFFFFFu << ROUGHNESS_BITS);
107 const uint v2_mask = ~(0xFFFFFFFFu << METALLIC_BITS);
108 uint idata = uint(data * float(total_mask));
109 v1 = float(idata & v1_mask) * (1.0 / float(v1_mask));
110 v2 = float(idata >> ROUGHNESS_BITS) * (1.0 / float(v2_mask));
111 }
112
113 float calculate_transparent_weight(float z, float alpha)
114 {
115 #if 0
116 / Eq 10 : Good for surfaces with varying opacity (like particles) /
117 float a = min(1.0, alpha * 10.0) + 0.01;
118 float b = -gl_FragCoord.z * 0.95 + 1.0;
119 float w = a * a * a * 3e2 * b * b * b;
120 #else
121 / Eq 7 put more emphasis on surfaces closer to the view. /
122 // float w = 10.0 / (1e-5 + pow(abs(z) / 5.0, 2.0) + pow(abs(z) / 200.0, 6.0)); / Eq 7 /
123 // float w = 10.0 / (1e-5 + pow(abs(z) / 10.0, 3.0) + pow(abs(z) / 200.0, 6.0)); / Eq 8 /
124 // float w = 10.0 / (1e-5 + pow(abs(z) / 200.0, 4.0)); / Eq 9 /
125 / Same as eq 7, but optimized. */
126 float a = abs(z) / 5.0;
127 float b = abs(z) / 200.0;
128 b = b;
129 float w = 10.0 / ((1e-5 + a * a) + b * (b * b)); / Eq 7 /
130 #endif
131 return alpha * clamp(w, 1e-2, 3e2);
132 }
133
134 / Special function only to be used with calculate_transparent_weight(). /
135 float linear_zdepth(float depth, vec4 viewvecs- [x], mat4 proj_mat)
136 {
137 if (proj_mat- [x]- [x] == 0.0) {
138 float d = 2.0 * depth - 1.0;
139 return -proj_mat- [x]- [x] / (d + proj_mat- [x][2]);
140 }
141 else {
142 / Return depth from near plane. /
143 return depth * viewvecs- [x].z;
144 }
145 }
146
147 vec3 view_vector_from_screen_uv(vec2 uv, vec4 viewvecs- [x], mat4 proj_mat)
148 {
149 return (proj_mat- [x]- [x] == 0.0)
150 ? normalize(viewvecs- [x].xyz + vec3(uv, 0.0) * viewvecs- [x].xyz)
151 : vec3(0.0, 0.0, 1.0);
152 }
153
154 vec2 matcap_uv_compute(vec3 I, vec3 N, bool flipped)
155 {
156 / Quick creation of an orthonormal basis /
157 float a = 1.0 / (1.0 + I.z);
158 float b = -I.x * I.y * a;
159 vec3 b1 = vec3(1.0 - I.x * I.x * a, b, -I.x);
160 vec3 b2 = vec3(b, 1.0 - I.y * I.y * a, -I.y);
161 vec2 matcap_uv = vec2(dot(b1, N), dot(b2, N));
162 if (flipped) {
163 matcap_uv.x = -matcap_uv.x;
164 }
165 return matcap_uv * 0.496 + 0.5;
166 }
167 uniform int object_id = 0;
168
169 uniform vec3 materialDiffuseColor;
170 uniform float materialMetallic;
171 uniform float materialRoughness;
172
173 uniform sampler2D image;
174 uniform float ImageTransparencyCutoff = 0.1;
175
176 #ifdef NORMAL_VIEWPORT_PASS_ENABLED
177 in vec3 normal_viewport;
178 #endif
179
180 #ifdef V3D_SHADING_TEXTURE_COLOR
181 in vec2 uv_interp;
182 #endif
183
184 #ifdef HAIR_SHADER
185 flat in float hair_rand;
186 #endif
187
188 #ifdef MATDATA_PASS_ENABLED
189 layout(location=0) out vec4 materialData;
190 #endif
191 #ifdef OBJECT_ID_PASS_ENABLED
192 layout(location=1) out uint objectId;
193 #endif
194 #ifdef NORMAL_VIEWPORT_PASS_ENABLED
195 layout(location=2) out WB_Normal normalViewport;
196 #endif
197
198 void main()
199 {
200 #ifdef MATDATA_PASS_ENABLED
201 float metallic, roughness;
202 vec4 color;
203
204 # ifdef V3D_SHADING_TEXTURE_COLOR
205 color = texture(image, uv_interp);
206 if (color.a < ImageTransparencyCutoff) {
207 discard;
208 }
209 # else
210 color.rgb = materialDiffuseColor;
211 # endif
212
213 # ifdef V3D_LIGHTING_MATCAP
214 / Encode front facing in metallic channel. /
215 metallic = float(gl_FrontFacing);
216 roughness = 0.0;
217 # else
218 metallic = materialMetallic;
219 roughness = materialRoughness;
220 # endif
221
222 # ifdef HAIR_SHADER
223 / Add some variation to the hairs to avoid uniform look. /
224 float hair_variation = hair_rand * 0.1;
225 color = clamp(color - hair_variation, 0.0, 1.0);
226 metallic = clamp(materialMetallic - hair_variation, 0.0, 1.0);
227 roughness = clamp(materialRoughness - hair_variation, 0.0, 1.0);
228 # endif
229
230 materialData.rgb = color.rgb;
231 materialData.a = workbench_float_pair_encode(roughness, metallic);
232 #endif / MATDATA_PASS_ENABLED */
233
234 #ifdef OBJECT_ID_PASS_ENABLED
235 objectId = uint(object_id);
236 #endif
237
238 #ifdef NORMAL_VIEWPORT_PASS_ENABLED
239 vec3 n = (gl_FrontFacing) ? normal_viewport : -normal_viewport;
240 n = normalize(n);
241 normalViewport = workbench_normal_encode(n);
242 #endif
243 }
shader string 1
1 #version 330
shader string 2
shader string 3
2 #define GPU_ATI
shader string 4
shader string 5
11 vec4 direction;
14 };
15
23 int num_lights;
28 int pad[3];
29 };
33
35
43 );
44
49 }
50
52
54
58 {
62 vec3 n;
63 n.xy = fencg;
64 n.z = 1 - f / 2;
65 return n;
66 }
67
71 {
74 return n.xy;
75 }
76
77 #else
83
89
92 {
99 }
100
102 {
109 }
110
112 {
113 #if 0
118 #else
126 b = b;
128 #endif
130 }
131
134 {
138 }
139 else {
142 }
143 }
144
146 {
150 }
151
153 {
160 if (flipped) {
162 }
164 }
165 vec3 background_color(WorldData world_data, float y) {
166 return mix(world_data.background_color_low, world_data.background_color_high, y).xyz + bayer_dither_noise();
167 }
168
169 / [Drobot2014a] Low Level Optimizations for GCN /
170 vec4 fast_rcp(vec4 v)
171 {
172 return intBitsToFloat(0x7eef370b - floatBitsToInt(v));
173 }
174
175 vec3 brdf_approx(vec3 spec_color, float roughness, float NV)
176 {
177 / Very rough own approx. We don't need it to be correct, just fast.
178 * Just simulate fresnel effect with roughness attenuation. /
179 float fresnel = exp2(-8.35 * NV) * (1.0 - roughness);
180 return mix(spec_color, vec3(1.0), fresnel);
181 }
182
183 void prep_specular(
184 vec3 L, vec3 I, vec3 N, vec3 R,
185 out float NL, out float wrapped_NL, out float spec_angle)
186 {
187 wrapped_NL = dot(L, R);
188 vec3 half_dir = normalize(L + I);
189 spec_angle = clamp(dot(half_dir, N), 0.0, 1.0);
190 NL = clamp(dot(L, N), 0.0, 1.0);
191 }
192
193 / Normalized Blinn shading /
194 vec4 blinn_specular(vec4 shininess, vec4 spec_angle, vec4 NL)
195 {
196 / Pi is already divided in the lamp power.
197 * normalization_factor = (shininess + 8.0) / (8.0 * M_PI) /
198 vec4 normalization_factor = shininess * 0.125 + 1.0;
199 vec4 spec_light = pow(spec_angle, shininess) * NL * normalization_factor;
200
201 return spec_light;
202 }
203
204 / NL need to be unclamped. w in [0..1] range. /
205 vec4 wrapped_lighting(vec4 NL, vec4 w)
206 {
207 vec4 w_1 = w + 1.0;
208 vec4 denom = fast_rcp(w_1 * w_1);
209 return clamp((NL + w) * denom, 0.0, 1.0);
210 }
211
212 vec3 get_world_lighting(
213 WorldData world_data,
214 vec3 diffuse_color, vec3 specular_color, float roughness,
215 vec3 N, vec3 I)
216 {
217 vec3 specular_light = world_data.ambient_color.rgb;
218 vec3 diffuse_light = world_data.ambient_color.rgb;
219 vec4 wrap = vec4(
220 world_data.lights- [x].diffuse_color_wrap.a,
221 world_data.lights- [x].diffuse_color_wrap.a,
222 world_data.lights- [x].diffuse_color_wrap.a,
223 world_data.lights- [x].diffuse_color_wrap.a
224 );
225
226 #ifdef V3D_SHADING_SPECULAR_HIGHLIGHT
227 / Prepare Specular computation. Eval 4 lights at once. /
228 vec3 R = -reflect(I, N);
229 vec4 spec_angle, spec_NL, wrap_NL;
230 prep_specular(world_data.lights- [x].direction.xyz, I, N, R, spec_NL.x, wrap_NL.x, spec_angle.x);
231 prep_specular(world_data.lights- [x].direction.xyz, I, N, R, spec_NL.y, wrap_NL.y, spec_angle.y);
232 prep_specular(world_data.lights- [x].direction.xyz, I, N, R, spec_NL.z, wrap_NL.z, spec_angle.z);
233 prep_specular(world_data.lights- [x].direction.xyz, I, N, R, spec_NL.w, wrap_NL.w, spec_angle.w);
234
235 vec4 gloss = vec4(1.0 - roughness);
236 / Reduce gloss for smooth light. (simulate bigger light) */
237 gloss = 1.0 - wrap;
238 vec4 shininess = exp2(10.0 * gloss + 1.0);
239
240 vec4 spec_light = blinn_specular(shininess, spec_angle, spec_NL);
241
242 / Simulate Env. light. /
243 vec4 w = mix(wrap, vec4(1.0), roughness);
244 vec4 spec_env = wrapped_lighting(wrap_NL, w);
245
246 spec_light = mix(spec_light, spec_env, wrap * wrap);
247
248 / Multiply result by lights specular colors. */
249 specular_light += spec_light.x * world_data.lights- [x].specular_color.rgb;
250 specular_light += spec_light.y * world_data.lights- [x].specular_color.rgb;
251 specular_light += spec_light.z * world_data.lights- [x].specular_color.rgb;
252 specular_light += spec_light.w * world_data.lights- [x].specular_color.rgb;
253
254 float NV = clamp(dot(N, I), 0.0, 1.0);
255 specular_color = brdf_approx(specular_color, roughness, NV);
256 #endif
257 specular_light = specular_color;
258
259 / Prepare diffuse computation. Eval 4 lights at once. /
260 vec4 diff_NL;
261 diff_NL.x = dot(world_data.lights- [x].direction.xyz, N);
262 diff_NL.y = dot(world_data.lights- [x].direction.xyz, N);
263 diff_NL.z = dot(world_data.lights- [x].direction.xyz, N);
264 diff_NL.w = dot(world_data.lights- [x].direction.xyz, N);
265
266 vec4 diff_light = wrapped_lighting(diff_NL, wrap);
267
268 / Multiply result by lights diffuse colors. /
269 diffuse_light += diff_light.x * world_data.lights- [x].diffuse_color_wrap.rgb;
270 diffuse_light += diff_light.y * world_data.lights- [x].diffuse_color_wrap.rgb;
271 diffuse_light += diff_light.z * world_data.lights- [x].diffuse_color_wrap.rgb;
272 diffuse_light += diff_light.w * world_data.lights- [x].diffuse_color_wrap.rgb;
273
274 / Energy conservation with colored specular look strange.
275 * Limit this strangeness by using mono-chromatic specular intensity. */
276 float spec_energy = dot(specular_color, vec3(0.33333));
277
278 diffuse_light = diffuse_color * (1.0 - spec_energy);
279
280 return diffuse_light + specular_light;
281 }
282 #define OBJECT_OUTLINE_OFFSET 1
283
284 float calculate_object_outline(usampler2D objectId, ivec2 texel, uint object_id)
285 {
286 uvec4 oid_offset = uvec4(
287 texelFetchOffset(objectId, texel, 0, ivec2(0, OBJECT_OUTLINE_OFFSET)).r,
288 texelFetchOffset(objectId, texel, 0, ivec2(0, -OBJECT_OUTLINE_OFFSET)).r,
289 texelFetchOffset(objectId, texel, 0, ivec2(-OBJECT_OUTLINE_OFFSET, 0)).r,
290 texelFetchOffset(objectId, texel, 0, ivec2( OBJECT_OUTLINE_OFFSET, 0)).r);
291
292 return dot(vec4(equal(uvec4(object_id), oid_offset)), vec4(0.25));
293 }
294 out vec4 fragColor;
295
296 uniform mat4 ProjectionMatrix;
297 uniform mat4 ViewMatrixInverse;
298
299 uniform usampler2D objectId;
300 uniform sampler2D materialBuffer;
301 uniform sampler2D normalBuffer;
302 / normalBuffer contains viewport normals /
303 uniform sampler2D cavityBuffer;
304 uniform sampler2D matcapImage;
305
306 uniform vec2 invertedViewportSize;
307 uniform vec4 viewvecs[3];
308 uniform float shadowMultiplier;
309 uniform float lightMultiplier;
310 uniform float shadowShift = 0.1;
311 uniform float shadowFocus = 1.0;
312
313 uniform vec3 materialSingleColor;
314
315 layout(std140) uniform world_block {
316 WorldData world_data;
317 };
318
319 void main()
320 {
321 ivec2 texel = ivec2(gl_FragCoord.xy);
322 vec2 uv_viewport = gl_FragCoord.xy * invertedViewportSize;
323
324 float roughness, metallic;
325 vec3 base_color;
326
327 #ifndef MATDATA_PASS_ENABLED
328 base_color = materialSingleColor;
329 metallic = 0.0;
330 roughness = 0.5;
331 #else
332 vec4 material_data = texelFetch(materialBuffer, texel, 0);
333 base_color = material_data.rgb;
334 workbench_float_pair_decode(material_data.a, roughness, metallic);
335 #endif
336
337 / Do we need normals /
338 #ifdef NORMAL_VIEWPORT_PASS_ENABLED
339 vec3 normal_viewport = workbench_normal_decode(texelFetch(normalBuffer, texel, 0).rg);
340 #endif
341
342 vec3 I_vs = view_vector_from_screen_uv(uv_viewport, viewvecs, ProjectionMatrix);
343
344 / -------- SHADING --------- /
345 #ifdef V3D_LIGHTING_FLAT
346 vec3 shaded_color = base_color;
347
348 #elif defined(V3D_LIGHTING_MATCAP)
349 / When using matcaps, the metallic is the backface sign. /
350 normal_viewport = (metallic > 0.0) ? normal_viewport : -normal_viewport;
351 bool flipped = world_data.matcap_orientation != 0;
352 vec2 matcap_uv = matcap_uv_compute(I_vs, normal_viewport, flipped);
353 vec3 matcap = textureLod(matcapImage, matcap_uv, 0.0).rgb;
354 vec3 shaded_color = matcap * base_color;
355
356 #elif defined(V3D_LIGHTING_STUDIO)
357
358 # ifdef V3D_SHADING_SPECULAR_HIGHLIGHT
359 vec3 specular_color = mix(vec3(0.05), base_color, metallic);
360 vec3 diffuse_color = mix(base_color, vec3(0.0), metallic);
361 # else
362 roughness = 0.0;
363 vec3 specular_color = vec3(0.0);
364 vec3 diffuse_color = base_color;
365 # endif
366
367 vec3 shaded_color = get_world_lighting(world_data,
368 diffuse_color, specular_color, roughness,
369 normal_viewport, I_vs);
370 #endif
371
372 / -------- POST EFFECTS --------- /
373 #ifdef WB_CAVITY
374 / Using UNORM texture so decompress the range */
375 shaded_color *= texelFetch(cavityBuffer, texel, 0).r * CAVITY_BUFFER_RANGE;
376 #endif
377
378 #ifdef V3D_SHADING_SHADOW
379 float light_factor = -dot(normal_viewport, world_data.shadow_direction_vs.xyz);
380 float shadow_mix = smoothstep(shadowFocus, shadowShift, light_factor);
381 shaded_color *= mix(lightMultiplier, shadowMultiplier, shadow_mix);
382 #endif
383
384 #ifdef V3D_SHADING_OBJECT_OUTLINE
385 uint object_id = texelFetch(objectId, texel, 0).r;
386 float object_outline = calculate_object_outline(objectId, texel, object_id);
387 shaded_color = mix(world_data.object_outline_color.rgb, shaded_color, object_outline);
388 #endif
389
391 }
Added subscriber: @TwingSister
Closed as duplicate of #59182
