Can't select mesh components in see-through mode. #59580
6 Participants
Reference: blender/blender#59580
Operating system: Windows10 x64
Graphics card: RTX 2080
Broken: 2.80.0
8839152abf
windows64(example: 2.79b release)
(example: 2.80,
edbf15d3c0
, blender2.8, 2018-11-28, as found on the splash screen)Worked: (optional)
Whenever i turn on the transparent view toggle (aka see-through mode), be it in wireframe mode or any other, I am completely unable to select any mesh subcomponents (vertices, edges, faces). Doesn't matter which selection tool i'm using.
Added subscriber: @foodi-4
Added subscriber: @SamuelPenning
Please provide a .blend file in which we can see the problem.
And maybe make a video that shows the issue.
Everything works when you are not in wireframe mode?
Yes, everything works except when you activate see through mode.
Blend file attached:Xray_BugReport.zip
Added subscriber: @BenjaminMuller
I can confirm this with the test file, with x-ray and wireframe mode. I tested with the build 'a91886e76ebd'.
To reiterate: The only way i was able to fix the problem was to reset the UI. Still no idea what caused it.
Added subscriber: @ideasman42
This issue was referenced by
61036ca179
