Armature layer dots not updated on changes
Open, Confirmed, MediumPublic
Win10
Gtx 980
Broken: 2.8 current build
Usually if an armature layer contained bones, a dot icon is used to show that it's not empty.
However when merging two armatures, if one armature contains bones in a hidden layer, the dot icon is not displayed after merging.
  • Open the blend file
  • There are two armature in the scene. "Armature1" contain one bone in the first layer (visible)."Armature2" contains one bone in a hidden layer (8)
  • Select "Armature2" then "Armature1". Ctrl-J to join.
  • The dot icon is missing on the 8th layer.
lucas veber (lucky3) renamed this task from Armature layers: dot not displayed on armature layers to Armature layers: dot not displayed.
Sebastian Parborg (zeddb) triaged this task as Confirmed, Medium priority.
I doesn't seem to matter which way I join or if the are visible or not.
If I join 1 to 2, only the dots from 2 is visible and if I join 2 to 1 only 1 dots are visible.
@Brecht Van Lommel (brecht) who to assign this to?
I don't know since when, but at least in c59370bf643f, the dots on armature layers don't display, period. Edit mode, pose mode, after joining separate armatures, nothing.
The only way I found was by appending a skeleton from a 2.79 blend. But even then, the dots that were there the moment it appended will stay there for ever, even if you delete every bone.
Demeter Dzadik (Mets) added a comment.EditedFeb 4 2019, 6:15 PM
This seems to be fixed as of at least a1ae04d15a9f, maybe longer. All the dots are working perfectly for me. Yay!!!
Edit: Fixed in pose mode only! :C If moving bones to different layers in edit mode, it's still broken.
Does not seem fixed in the latest daily build.
Yes, today I tried on several computers and does not work, there is no indication.
Brecht Van Lommel (brecht) renamed this task from Armature layers: dot not displayed to Armature layer dots not updated on changes.
I test with recent builds, script generate new edit-bone (bn) for armature, at same time set bone layer , bn.layers[16] = True
bn.layers[0] = False
bone move to layers 16, but the dot of layer 16 not up-date. and there seems no way to force up-date from blender UI
I want to recommend this bug to be considered High prio, since I think it will confuse or even turn off a lot of people from 2.80, if god forbid it stays in for the final release. Just a thought tho.
