Stencil not appearing in Stencil Texture Paint mode in Blender 2.8 on Mac OS #59722
5 Participants
Reference: blender/blender#59722
Operating system: Mac OS Mojave v10.14.2
Graphics card: Radeon Pro 580 8192 MB
Broken: Stencil painting
2.80 Beta, 2018-12-20
(example: 2.80,
edbf15d3c0
, blender2.8, 2018-11-28, as found on the splash screen)Worked: (optional)
Stencil not appearing when Mapping is in Stencil mode; other Mappings, e.g. tile work ok
Added subscriber: @hboteler
In Texture Paint mode, the background texture does not appear when Mapping is in Stencil mode; all the other Mappings, however, such as 'tiled' and 'random' work ok. I have reported this in blender.stackexchange and was advised to report it here as a bug report.
Added subscriber: @ZedDB
I can sort of reproduce this on my end. The stencil texture is not repeated across the screen but it is just the full texture stuck at the bottom left of the screen. The offset and scale doesn't seem to make the area any bigger.
Added subscriber: @brecht
Please attach a .blend file to demonstrate the problem.
Never mind, that was how it is supposed to work...
I can not reproduce this on my end then.
Do you use any specific textures?
Does it work if you reset to factory defaults?
I attach the .blend file that was a follow-along to Jayanam's Youtube tutorial 'Blender 2.8: Eevee & Texture Paint' (1 Nov 2018).
Texture Paint & Stencil Cube.blend
There is no texture set up in this file that I can see, and the Overlays panel has display of textures disabled.
Do you have a .blend file that is fully set up to show the texture, but then doesn't show it? Otherwise it's difficult to tell if it's a setup problem, or maybe some problem specific to macOS or you graphics card.
Sorry, last Blend file was not up to date so I include another with texture packed. I have just downloaded and tried out the latest Mac OS build and have been able to try this file out on two different iMacs, with different results. On the most recent one (stats provided above) the same problem persists: I can paint with all Mappings except Stencil, and the background image does not appear. However, on the older iMac, I can paint in Stencil mode, although I still can't get the actual background image to appear. This older iMac (mid-2011) is operating on High Sierra 10-13-6 with an AMD Radeon HD 6970M 2048 MB Graphics card. Do you think there might be a problem with the new Mojave OS? Texture Paint Cube4.blend
Further experimentation with the new iMac on Mojave: using the same file above (Texture Paint Cube4), I moved the cube down to the bottom left corner of the viewport and now I can see the stencil painting working, although as with on the other iMac, the background image is not visible so I am unable to position it - I admit this might be something I'm not doing but can't see what.
That file seems to work flawlessly on my linux machine:
So I'm guessing this is mac related.
Could you run blender with
--debug-gpu
and then attach the output here (after you have tried to get the stencil to appear).You could also try
--debug-gpu-force-workarounds
and see if that help.Sorry, but I am guessing this has something to do with running scripts, which as yet I'm totally unfamiliar with - only started using Blender (2.7) this Autumn! I can do it if you guide me through the steps... otherwise might be quicker to get someone else to try it out!
Those are terminal options you append when starting blender.
So open up a terminal and navigate to where you have the blender binary and run
./blender --debug-gpu > output
. The output will now be saved to the fileoutput
in that directory.Che?? Don't even know what a 'terminal option' is, but I've noticed you've assigned this task to Clément Foucault, so I'm keeping my fingers crossed and relying on him! Sorry to be such a pain!
He will want this output too.
Here is a guide how to use the terminal: https://macpaw.com/how-to/use-terminal-on-mac
Still out of my depth here. Can navigate to the file using Terminal (I presume you mean my project file 'Texture Paint Cube4.blend' when you say 'binary file'?), but getting 'Permisssion denied' when typing in either '--debug-gpu' or './blender --debug-gpu > output'
I meant that you should start blender via the terminal. blender binary == blender program.
How to start blender via the terminal is explained in the first part here: https://blender.stackexchange.com/questions/2078/how-to-use-blender-command-lines-in-osx
Added subscriber: @lancelet
Patch for this:
Root cause: AFAICT,
GL_TEXTURE0
is aGLenum
, and not an integer index. When setting the uniform variableimage
for the shader, an integer index is required.See https://www.khronos.org/opengl/wiki/Sampler_(GLSL)#Binding_textures_to_samplers
You can see that
immUniform1i
is already used with an integer index atsource/blender/editors/sculpt_paint/paint_cursor.c
line 778.This is pretty confusing (took me a few days to track it down), but essentially it's a type error.
Edit: you can read my bug-fixing journey for this one on Twitter if you want: https://twitter.com/jmerritt/status/1076113441956360194
This issue was referenced by
410142caff
@lancelet, thanks for finding this!
Yes, my thanks too! I looked at your 'bug-fixing journey' on Twitter and appreciate the effort it took!
