Collada Export Missing Keyframes #59743
Reference: blender/blender#59743
Operating system: macOS Mojave 10.14.1
Graphics card: Radeon Pro 560X 4096 MB
Broken: version: 2.80 (sub 39), branch: blender2.8, commit date: 2018-12-21 21:14, hash:
f1f8859ad5
Worked: version: 2.79 (sub 0), branch: master, commit date: 2018-03-22 14:10, hash:
f4dc9f9
Missing location/rotation keyframe on bone named "RifleFrame" upon Collada export. Found that if I adjust the location of the "RifleFrame" bone and add a keyframe then exported animation will show "RifleBone" in correct location.
Screenshot of Collada Export working properly in 2.79b with following settings and files.
SoldierRun279b.blend
Working279b.dae
Screenshot of Collada Export not working properly in 2.80 with following settings and files.
SoldierRun280.blend
Broken280.dae
Update
I made all objects local and removed unnecessary textures, hopefully these new updated files work better for you. Please let me know if you get any more problems with my blend files.
Blender File 2.80
SoldierRun280.blend
Blender File 2.79b
Added subscriber: @Phi
I can not open the blend file:
I suspect that not all data is in your blendfile.
This issue was referenced by
4b7596ec91
hi, Phi;
Thanks for the updated blendfiles.
The problem was that you used the RifleFrame just for placing the rifle at the back of the model.
Since this bone is not animated otherwise (has a static pose) the animation exporter
removed this bone from the exported animation.
I see how this optimization fails in your case. So i added a new option for exporting flat curves.
But note: I also found another issue with an unexpected additional offset that hovers the
model above ground. I will look at that separately.
cheers,
Gaia
Thanks for getting the issue resolved, looking forward to the new option to export flat curves. I wasn't even aware of the second issue, great catch!
Fortunately the unexpected behavior is actually very expected but it needs to be documented better. The problem is that Collada does not support bone chains (connected bones) out of the box. While this is not very important for importing models to target systems (game engines) it is a bit annoying when you want to move a model between 3D editing tools.
To solve this i have added 2 options to the Collada Importer for automatic recognition of bone chains, but this recognition fails sometimes. In your case the Skeleton was auto connected to the CenterMass bone and thus it changes the animation. The good news is that the fix is super easy. Also the Importer can be told to not auto connect to avoid the issue at all:
Here are 2 cases and fixes:
Case 1: Model was exported from Blender with the Extra Option Use Blender profile
In that case disable following import options:
You then get the perfect import (lossless)
Case 2: Model was not exported from Blender or...
...or Model was exported from Blender without using the Blender Profile
In that case enable following import options:
After importing the model, edit the imported rig and disconnect the CenterMass bone from theSkeleton bone.
I think the current solution is the best we can achieve. However any hints for further improvement are very welcome.
