General problems with Blender's new default theme #59796
2 Participants
Reference: blender/blender#59796
This is technically not a bug but I had no idea what would be an appropriate place to post this so that the proposal would receive a proper evaluation.
TL;DR Blender's default theme has issues with consistency, visual hierarchies, color coding, neutrality of the ui and is generally too busy once things get more complex. Here is a direct comparison of the default theme in a complex situation with my proposa (I suggest loading both images in tabs and then go back and forth to see the difference)l:
The theme files can be found at the end of this post.
Good themes contribute to UI/UX for instance by helping to ensure clarity through consistently designed controls and by using colors in meaningful ways. Blender's new default theme looks great with simple scenes but when used for serious and more complex work things quickly become quite messy. I created a test scene that gives an overview of many editors in action. I used that scene to evaluate the current default theme and to create my proposal.
Problems of the current default theme
My proposal
Semi flat version:
Flat version:
I tried to resolve the described issues in my proposal. Following I will give a quick overview over what was done and the reasoning.
Two versions
I created two versions: a flat one and a semi flat one. The semi flat one uses subtle 3D-effects to differentiate controls from inputs while the flat version has to rely on the harder to grasp visual encodings of shapes and shade variation. Therefore I personally favor the semi flat version as it allows for clearer encoding of the different control-types. The main motivation to create the entirely flat one was to cater to potential style preferences and to prevent the proposal from not being considered for fashion reasons.
Conclusion
I am sure there are still things that can be improved upon. Also Blender's very fine grained theme editor makes it quite hard to come up with a perfectly consistent solution. However I believe this to be at the very least a good starting point and I hope that the screenshot-comparisons above make a strong enough point to make you consider my proposal.
Finally a prettier and less escalated screenshot:
okapi-dark-flat.xml okapi-dark.xml
Afterthoughts: bugs, technical issues & limitations
There are some details that can't be themed right now from what I understand:
Added subscriber: @okapi
Added subscriber: @brecht
Please see the explanation on the bug submission page:
