not abler to type in folder names when trying to save work either #59989
Closed
opened 2018-12-30 18:02:48 +01:00 by Richard Mason · 19 comments
Operating system: Windows 10
Graphics card: MSI Nvidia Geforce 1080 gaming x
processor: AMD 1800X 32GB ram running 2933mhz
Broken: 2.80 2018-12-28 23.19 Hash:7c438e5366b2
it appears that trying to type anything in to any field has been disabled
open any scene and then try to save nothing is able to be typed in to the fields by keyboard so you can not save work unless in a untitled.blend file
Regards
Richard
**System Information** Operating system: Windows 10 Graphics card: MSI Nvidia Geforce 1080 gaming x processor: AMD 1800X 32GB ram running 2933mhz **Blender Version** Broken: 2.80 2018-12-28 23.19 Hash:7c438e5366b2 **it appears that trying to type anything in to any field has been disabled** ****open any scene and then try to save nothing is able to be typed in to the fields by keyboard so you can not save work unless in a untitled.blend file**** Regards Richard
Author
Added subscriber: @Handsoff
#59988 was marked as duplicate of this issue
Added subscriber: @StephenSwaney
Cannot reproduce with 30-Dec build on Linux.
Are you clicking in filename text box to give it focus?
Cannot reproduce with 30-Dec build on Linux. Are you clicking in filename text box to give it focus?
Added subscriber: @ZedDB
I can not reproduce this either...
Author
it is a windows 10 as in description
Author
this is where it is not able to type in!
![area of typinguntitled.blend.JPG](https://archive.blender.org/developer/F6130569/area_of_typinguntitled.blend.JPG) this is where it is not able to type in!
Does it work if you navigate to your users documents folder?
Author
no it does not..
I have tried also changing the keyboard out and no difference.
I have also downloaded the latest version today still the same.
Works fine in 2.79 and 2.8 early version that i have tried.
no it does not.. I have tried also changing the keyboard out and no difference. I have also downloaded the latest version today still the same. Works fine in 2.79 and 2.8 early version that i have tried.
I'm guessing this is related to #59988.
Does it work if you reset to factory defaults in blender?
File -> Load Factory Settings
I'm guessing this is related to #59988. Does it work if you reset to factory defaults in blender? File -> Load Factory Settings
Author
yes both are related my bad for entering two reports.
No it does not work either if i set factory default or any customer the keyboard both Razor synapse 3 and Steel Series 3 are not being picked up by the program.
I would think it is an assignment issue in the registry.
As it works every where else apart from in 2.80 from 30122018 version
yes both are related my bad for entering two reports. No it does not work either if i set factory default or any customer the keyboard both Razor synapse 3 and Steel Series 3 are not being picked up by the program. I would think it is an assignment issue in the registry. As it works every where else apart from in 2.80 from 30122018 version
Added subscriber: @brecht
@brecht any windows people that can help?
Author
I have now had a chance to go through all keyboard commands and short cuts none are working on 30 & 31 12 2018 build. even to delete item by selecting it and then pressing x does not work in windows version.
Swapping out windows version to Linux version it works fine.
Happy New Year to everyone
I have now had a chance to go through all keyboard commands and short cuts none are working on 30 & 31 12 2018 build. even to delete item by selecting it and then pressing x does not work in windows version. Swapping out windows version to Linux version it works fine. Happy New Year to everyone
Added subscriber: @Karmacop
I'm on WIndows 10 (1607) using build 7c438e5366 and I can't reproduce.
I'm on WIndows 10 (1607) using build 7c438e5366b2 and I can't reproduce.
Author
Solved the Issue
It is to do with the firewall catching 3 sections of the blender software, "Cohost", "keyboard" "modkeys" if memory serves me correctly. I have tried it on another four window machines and one that worked was not using the "Comodo security"
After setting the Comodo to allow these 3 sections it is now working fully in all areas of the interface and saving files.
For anyone else having this issue check your Security and firewall settings and then set to allow.
Thank you all for your help in trying to sort this out it was just so frustrating to not know what was causing it.
Happy New Year to you all
Solved the Issue It is to do with the firewall catching 3 sections of the blender software, "Cohost", "keyboard" "modkeys" if memory serves me correctly. I have tried it on another four window machines and one that worked was not using the "Comodo security" After setting the Comodo to allow these 3 sections it is now working fully in all areas of the interface and saving files. For anyone else having this issue check your Security and firewall settings and then set to allow. Thank you all for your help in trying to sort this out it was just so frustrating to not know what was causing it. Happy New Year to you all
Sebastian Parborg self-assigned this 2019-01-02 02:30:13 +01:00
5 Participants
Reference: blender/blender#59989
