Single column layout breaks file browser #60037
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#60037
Operating system: Windows 10 64-bit
Graphics card: Nvidia GeForce GTX 1080Ti
Broken: 4d795cee4938
Setting
as recommended in the documentation causes non-responsive file/directory browser button on StringProperty with subtype set to "DIR_PATH". Clicking the button will not open the file browser.
Load and run the script. It creates a panel in Render > Hair Sample Render.init.py
Added subscriber: @rjg
Single column layout breaks file dialogto Single column layout breaks file browserI believe this is a bug and unless use_property_split should not be used in certain situations. If that is the case the documentation should reflect this.
This issue was referenced by blender/blender@8063d72b08
