Memory leak on fluid simulation #60062
Reference: blender/blender#60062
Operating system: Windows 10
RAM: 16 GB
Graphics card: NVIDIA Geforce GTX 960m
Broken:
hash:
26d5a3625e
, blender2.8, 2018-11-29Short description of error
The .blend file: water_simulation.blend
Added subscriber: @VitalyEgorov
Memory leak on fluid simulation AND Particle Info node doesn't work on Eeveeto Memory leak on fluid simulationAdded subscriber: @brecht
Please follow the bug submission guidelines:
But particle node support is not a bug, rather a documented limitation:
https://docs.blender.org/manual/en/dev/render/eevee/materials/nodes_support.html#input-nodes
Added subscriber: @ZedDB
Are you sure you are not just running out of RAM? As you said it already take up a lot of RAM (and it is already a bit close to you total 16GB).
It is expected that high resolution fluid sims takes up a lot of ram and is very slow.
Do you get this problem with 2.79?
I tried in blender 2.79b and it took 1 GB for this simulation.
Can you try the 2.79 build from here: https://builder.blender.org/download/ ?
I run out of memory in the latest 2.79 build too.
If you do not, could you provide the 2.79 file?
So, I found out that in my simulation there were two objects with ~30000 faces. I tried replace them with spheres and everything worked perfectly. Thanks for help. But I have the question - how many RAM PC mast have for blender working perfectly? 32GB is enough?
So this didn't work in 2.79? If it takes a lot less ram, then you probably have found a problem.
RAM depends on what you are doing. If you really tried, you could do things that go over 32GB. But in most cases, that means that you have gone overkill on something.
