Symmetrize/Bones work inconsistently and/or incorrectly. #60129
Reference: blender/blender#60129
Operating system: Windows 10 Pro
Graphics card: GTX 1070
Broken: 2.80, 2019-01-01 15:44 Hash:
4dd0a90f42
Same blend file, same processes and steps, different results for bones and the symmetrize function. See supplied .blend file for annotations and issues. Basic test cube works as expected, Jeep doesn't work.
Open .blend file and play around with the armatures for the cube, and for the Jeep. The bone for the cube pulls the opposite, mirrored side in the same direction, where the Jeep is pushed in the opposite direction. If you go into either armature, enter edit mode, symmetrize the bone, you will get the opposite bone as expected. If you create the associated vertex groups, only the cube will work as intended. The Jeep will ignore the new bone and continue mirroring the original R.Fender_Morph bone. (The same can be said of the other two mirrored bones, R.Quarter_Morph and R.Fender_Tip)
I've not done anything different in setup of either object, the mirrors are set the same, the armatures are set the same. If a setting somewhere is being changed, it's not me changing it, and I've been unable to locate any differences in settings either in the mirror, the objects or the armatures.
SymetrizeBug.zip
Added subscriber: @HardRooster
Added subscriber: @emu-3
I believe this is caused by a different order of Mirror and Armature modifiers in each object.
I separated the behavior in the attached file. Can you please confirm if it is the same effect as your example file?
armaturror.blend
Added subscriber: @mont29
We do not handle user support on this tracker, only bug reports. User forums like blenderartists.org or blender.stackexchange.com should be used for that matter.
Indeed modifier order is the issue here, no bug.
