Black viewport with Windows + GTX 860M #60152
Closed
opened 2019-01-04 12:52:50 +01:00 by Roman · 6 comments
Operating system: Windows 8.1
Graphics card: Nvidia GeForce GTX 860m
Broken: blender-2.80.0-git.c97c76c01c1d-windows64
(example: 2.79b release)
(example: 2.80, edbf15d3c0, blender2.8, 2018-11-28, as found on the splash screen)
Startup viewport is black, the same problem with objects (not correct also with changing solid/wireframe view etc.), impossible to highlight vertexes, edges, and polygons, they are highlighted only when pressed central mouse button(wheel) and mouse is moved. After mouse stopping - every highlighted parts just disappears.
  1. Start Blender.exe
  2. Go to Edit Mode.
  3. Change Solid, wireframe or other view and move object.
  4. Change solid, wireframe etc. view again to see the differences.
  5. Try to select vertex, edge, polygon, then turn the object.
**System Information** Operating system: Windows 8.1 Graphics card: Nvidia GeForce GTX 860m **Blender Version** Broken: blender-2.80.0-git.c97c76c01c1d-windows64 (example: 2.79b release) (example: 2.80, edbf15d3c044, blender2.8, 2018-11-28, as found on the splash screen) Worked: (optional) **Short description of error** Startup viewport is black, the same problem with objects (not correct also with changing solid/wireframe view etc.), impossible to highlight vertexes, edges, and polygons, they are highlighted only when pressed central mouse button(wheel) and mouse is moved. After mouse stopping - every highlighted parts just disappears. **Exact steps for others to reproduce the error** Based on the default startup or an attached .blend file (as simple as possible). 1. Start Blender.exe 2. Go to Edit Mode. 3. Change Solid, wireframe or other view and move object. 4. Change solid, wireframe etc. view again to see the differences. 5. Try to select vertex, edge, polygon, then turn the object.
Author
Added subscriber: @Ron-P
Author
![1.jpg](https://archive.blender.org/developer/F6171368/1.jpg) ![2.jpg](https://archive.blender.org/developer/F6171371/2.jpg) ![3.jpg](https://archive.blender.org/developer/F6171373/3.jpg)
Added subscriber: @brecht
Please try:
  • File > Load Factory Settings, and see if the issue remains.
  • If you have a laptop with both an integrated and NVIDIA GPU, configure Blender to run with the NVIDIA GPU .
  • Installing the latest graphics drivers from the NVIDIA website.
  • If that doesn't help, please attach the output of Help > System Info.
Please try: * File > Load Factory Settings, and see if the issue remains. * If you have a laptop with both an integrated and NVIDIA GPU, [configure Blender to run with the NVIDIA GPU ](https://nvidia.custhelp.com/app/answers/detail/a_id/2615/~/how-do-i-customize-optimus-profiles-and-settings%3F). * Installing the latest graphics drivers from the NVIDIA website. * If that doesn't help, please attach the output of Help > System Info.
Brecht Van Lommel changed title from Bugs to Black viewport with Windows + GTX 860M 2019-01-04 18:36:59 +01:00
Author
I'm a lucky man today. Configuring Blender to run with NVIDIA GPU helps in this sutiation.
For me, as an ex-3dsMax user, to work with prrevious 2.79 interface was terrible to start, but 2.80 interface is really fantastic.
Thank you very much!
I'm a lucky man today. Configuring Blender to run with NVIDIA GPU helps in this sutiation. For me, as an ex-3dsMax user, to work with prrevious 2.79 interface was terrible to start, but 2.80 interface is really fantastic. Thank you very much!
Closed as duplicate of #59014
2 Participants
Reference: blender/blender#60152
