Offset custom button in Header
Operating system: windows 10 64
Graphics card: gtx 904m
2.80, a77b63c56943 2019.01.04 21:18
addon
Install
Vlad (Darcvizer) updated the task description. (Show Details)
Sebastian Parborg (zeddb) lowered the priority of this task from 90 to 30.Feb 11 2019, 4:45 PM
Could you just create a minimal .blend file where all we would have to do is to run a bundled script?
There is a lot of bug reports ATM so making it fast and easy for us to reproduce this would be really great.
I do not know how to make such a file. But I can give you my config.
I mean that you will have code in the text editor in blender and then you can simply attach a .blend file that we can open and hit Run Script to reproduce the issue.
OK. This is another addon. But he has the same problem.
Sebastian Parborg (zeddb) lowered the priority of this task from 30 to Low.
Richard Antalik (ISS) changed the subtype of this task from "Report" to "Known Issue".
Registering multiple headers for the same region isn't supported, I've committed rB4b20eebb85cc: UI: only draw a single header in the header region because it's only going to cause problems.
If you want to add a button to a header you can append it to the existing headers.
Closing.
Campbell Barton (campbellbarton) changed the subtype of this task from "Known Issue" to "Report".Sep 21 2020, 7:58 AM
