2nd link cannot be dragged out of Ambient Occlusion node's Color output after undo or reload. #60324
Reference: blender/blender#60324
{F6221233}System Information
Operating system: Win10
Broken:
2.80,
2edd32c168
, blender2.8, 2019-01-06If you drag a link from the Ambient Occlusion node's Color output, then cut this link, and then undo that cut, you will no longer be able to drag additional links out of the output pin. Instead, you will grab the existing link. The same thing happens without undo, if you simply save and reload the file.
Reproduction steps:
In the node editor, spawn an Ambient Occlusion node.
Method 1: Connect the color output to anything, cut the link, and then undo.
Method 2: Save and reload the blend.
Now whenever you try to drag from the Color output pin when there is already a link, you will be dragging the existing link, rather than creating a new one, which is the expected behaviour for input pins, but not for output pins.
For now the workaround to this is to drag from your desired output into the input pin.
Added subscriber: @Mets
Added subscriber: @ZedDB
I can reproduce this too. I'm guessing that some flags do not get properly reset on undo/reload.
This issue was referenced by
1c42f1c5ca
