Can't weld vertices that are ontop of each other in the UV editor #60396
Reference: blender/blender#60396
Operating system: Windows 7
Graphics card: Geforce GTX 1060
Broken: 2.80, hash:
96f762500e
, 2019-01-07Short description of error
Vertices that are very, very close to each other that they are on top of one another can't be welded together using weld/remove doubles UV in the weld/align menu.
One workaround I found to this problem is to slightly move one vertex away from the other vertex, then select both and weld them again. Then it works.
Added subscriber: @Frozen_Death_Knight
Added subscriber: @lichtwerk
Not sure if I understand correctly:
The Weld tool will move selected UVs to their average position, they will remain separate entities though.
If you weld two UVs that are slightly apart then these will hop into the same location [thats what you call "it works"], but you can still select one or the other, no?
So, unless I am misunderstanding something, two UVs can never be made into a single one.
So, how do you merge the UV map vertices together then? Even when I haven't made a seam or split the UV, some vertices still remain split and can be move away from each other. When I used weld inside Blender it looked like to me that they became merged as one vertix since the two vertices were no longer selectable on their own after doing that workaround I mentioned.
Either way, the mesh was behaving differently after I did it, so I don't know what else to tell you.
Added subscriber: @brecht
In Blender all UV map vertices are separated. What happens is that selection tools use the Sticky Selection setting from the header, set to Shared Location by default. So if you click on a UV map vertex in the UV editor, it will automatically select other UV map vertices that belong to the same mesh vertex and have the same location. A tool like weld simply moves UV map vertices to the same location.
If you still think there is a bug, we need more exact steps to redo the problem. Maybe attach a .blend file saved after step 5.
Since no further information was provided, I'll assume this is not a bug.
