Shapekey transfer cause the crash of blender #60401
Reference: blender/blender#60401
Operating system: Window 10 64bit
Graphics card: PNY Nvidia GTX 1060
Broken:
blender-2.80-80ffa73b3f87-win64
I attached a blend file that contains the problem , so basically i am trying to transfer shapekeys from a model named "Pattern" to another model named "Pattern1" that have no shapekeys that cause the crash of blender and outputs this in the console :
Error : EXCEPTION_ACCESS_VIOLATION
Address : 0x00007FF76B4C0963
Module : C:\Users\test\Downloads\blender-2.80-80ffa73b3f87-win64\blender-2.80.0-git.80ffa73b3f87-windows64\blender.exe
This problem happens for those models only for some reason
Selecting the model "Pattern" first then selecting the model "Pattern1"
On shapekeys panel i press on arrow and select "Transfer Shape key"
and it crashes
bug.blend
Added subscriber: @MaTcHo0o
#60249 was marked as duplicate of this issue
Added subscribers: @mont29, @lichtwerk
Confirmed.
key->from
is NULL here@mont29: is this for you?
Seems to be exact same issue as #60249, so answer will be the same. :)
That file is invalid (NULL back-pointer from shape key to its owner geometry). Afraid we cannot do much unless we get precise reproducible steps to create such a file.
Two people getting same exact issue “that should not happen” is kinda serious, so would be really nice to know how those invalid files can be generated. :|
Ok will try to use some backup that i have of the files and look for how those file get generated and do some debugging .
This python command also cause the crash : "C.object.data.shape_keys.key_blocks- [x].relative_key.data[vertex_index]" i don't know if this helps to give any idea about the source of the issue .
And i didn't get any message of the response you did on my email for some reason
@MaTcHo0o source of the issue in current file is very well known (NULL pointer that should never be NULL, ever). Many different kind of accesses/operations on shapekeys will henceforth crash Blender. So current file is corrupted. Question is, how to get to that point? ;)
PS: some mail services/client tend to tag messages from this tool/website as spam, this could explain your lack of mail notification maybe.
@mont29 I believe i found why it happens to those models ,so basically if you have a model with no shapekey at all not even the basis if you used the "apply as shapekey" from simple deform modifier for example the basis created from this will be corrupted and will cause the crash of blender when you try an operation related to it , but if the model have a basis and you click on "apply as shapekey" from simple deform modifier for example it will work with no problem .
So i think the basis created from apply as shapekey of a modifier is corrupted .
Please let me know if this is correct and if it have a workaround to make it work because i have a model for a client with 8 shapekeys that have the same problem and want to know should i recreate everything from scratch or wait for a solution.
Thanks, can confirm indeed, in fact we are setting C.object.data.shape_keys.user to evaluated (hence temp, never saved) version of the object, instead of the actual original object (that’s thanks to CoW ;) ). Should be easy to fix.
Added subscriber: @ngzaharias
This issue was referenced by
47be4e9a33
