Blender crashes when dragging objects from appended scene #60432
Closed
opened 2019-01-12 00:39:05 +01:00 by Ryan · 6 comments
Blender crashes when attempting to add objects from an appended scene when dragging from scene in outline to viewport.
System Info:
OS: Windows 10 Education
Graphics Card: NVIDIA GeForce GTX 1070
Blender 2.8 Hash: 80ffa73b3f
Steps to reproduce:
  1. Reset to Factory Settings
  2. Load test1.blend
  3. Select Append... Then select test2.blend, then Scene, then select Scene
  4. Select Scene View in Outliner
  5. Expand Hierarchy to show objects in Scene.001
  6. With test1 scene as Active Scene, drag Sphere object into 3D Viewport.
Result: Blender crashes.
test1.blend
test2.blend
Blender crashes when attempting to add objects from an appended scene when dragging from scene in outline to viewport. **System Info:** OS: Windows 10 Education Graphics Card: NVIDIA GeForce GTX 1070 **Blender Version** Blender 2.8 Hash: 80ffa73b3f87 **Steps to reproduce:** 1. Reset to Factory Settings ![image.png](https://archive.blender.org/developer/F6259579/image.png) 2. Load test1.blend ![image.png](https://archive.blender.org/developer/F6259586/image.png) 3. Select Append... Then select test2.blend, then Scene, then select Scene ![image.png](https://archive.blender.org/developer/F6259594/image.png) ![image.png](https://archive.blender.org/developer/F6259603/image.png) 4. Select Scene View in Outliner ![image.png](https://archive.blender.org/developer/F6259622/image.png) 5. Expand Hierarchy to show objects in Scene.001 ![image.png](https://archive.blender.org/developer/F6259634/image.png) 6. With test1 scene as Active Scene, drag Sphere object into 3D Viewport. ![image.png](https://archive.blender.org/developer/F6259648/image.png) Result: Blender crashes. [test1.blend](https://archive.blender.org/developer/F6259556/test1.blend) [test2.blend](https://archive.blender.org/developer/F6259557/test2.blend)
Author
Added subscriber: @mrlee
Added subscriber: @ZedDB
Bastien Montagne was assigned by Sebastian Parborg 2019-01-28 11:37:19 +01:00
When appending the scene I get the following assert in the debug build:
BLI_assert failed: blender/source/blender/blenlib/intern/BLI_ghash.c:466, ghash_insert_ex(), at '(gh->flag & GHASH_FLAG_ALLOW_DUPES) || (BLI_ghash_haskey(gh, key) == 0)'
Without that assert, I can reproduce the crash. Here is the bt:
Thread 1 "blender" received signal SIGSEGV, Segmentation fault.
0x00005555575f0a9a in object_add_duplicate_internal (bmain=0x7fff9f752408, scene=0x7fffd16de008, view_layer=0x7fffe9d23ac8, ob=0x7fff9f7e9008, dupflag=1599)
    at /home/zed/programmering/blender_master/blender/source/blender/editors/object/object_add.c:2243
2243			basen->local_view_bits = base->local_view_bits;
(gdb) bt
#0  0x00005555575f0a9a in object_add_duplicate_internal (bmain=0x7fff9f752408, scene=0x7fffd16de008, view_layer=0x7fffe9d23ac8, ob=0x7fff9f7e9008,
    dupflag=1599) at /home/zed/programmering/blender_master/blender/source/blender/editors/object/object_add.c:2243
#1  0x00005555575f20d5 in add_named_exec (C=0x7ffff0030288, op=0x7fff9e03b048)
    at /home/zed/programmering/blender_master/blender/source/blender/editors/object/object_add.c:2592
#2  0x00005555570ec4df in wm_operator_invoke (C=0x7ffff0030288, ot=0x7fffead0ab08, event=0x7fff9dcb0108, properties=0x7fffde6c6f08, reports=0x0,
    poll_only=false, use_last_properties=true) at /home/zed/programmering/blender_master/blender/source/blender/windowmanager/intern/wm_event_system.c:1343
#3  0x00005555570ecce2 in wm_operator_call_internal (C=0x7ffff0030288, ot=0x7fffead0ab08, properties=0x7fffde6c6f08, reports=0x0, context=0, poll_only=false,
    event=0x7fff9dcb0108) at /home/zed/programmering/blender_master/blender/source/blender/windowmanager/intern/wm_event_system.c:1576
#4  0x00005555570ef07f in wm_handlers_do_intern (C=0x7ffff0030288, event=0x7fff9dcb0108, handlers=0x7fff9e0615d8)
    at /home/zed/programmering/blender_master/blender/source/blender/windowmanager/intern/wm_event_system.c:2416
#5  0x00005555570ef860 in wm_handlers_do (C=0x7ffff0030288, event=0x7fff9dcb0108, handlers=0x7fff9e0615d8)
    at /home/zed/programmering/blender_master/blender/source/blender/windowmanager/intern/wm_event_system.c:2618
#6  0x00005555570f0f96 in wm_event_do_handlers (C=0x7ffff0030288)
    at /home/zed/programmering/blender_master/blender/source/blender/windowmanager/intern/wm_event_system.c:3093
- 7  0x00005555570e5885 in WM_main (C=0x7ffff0030288) at /home/zed/programmering/blender_master/blender/source/blender/windowmanager/intern/wm.c:425
- 8  0x00005555570e016e in main (argc=1, argv=0x7fffffffdd08) at /home/zed/programmering/blender_master/blender/source/creator/creator.c:520
When appending the scene I get the following assert in the debug build: `BLI_assert failed: blender/source/blender/blenlib/intern/BLI_ghash.c:466, ghash_insert_ex(), at '(gh->flag & GHASH_FLAG_ALLOW_DUPES) || (BLI_ghash_haskey(gh, key) == 0)'` Without that assert, I can reproduce the crash. Here is the bt: ``` Thread 1 "blender" received signal SIGSEGV, Segmentation fault. 0x00005555575f0a9a in object_add_duplicate_internal (bmain=0x7fff9f752408, scene=0x7fffd16de008, view_layer=0x7fffe9d23ac8, ob=0x7fff9f7e9008, dupflag=1599) at /home/zed/programmering/blender_master/blender/source/blender/editors/object/object_add.c:2243 2243 basen->local_view_bits = base->local_view_bits; (gdb) bt #0 0x00005555575f0a9a in object_add_duplicate_internal (bmain=0x7fff9f752408, scene=0x7fffd16de008, view_layer=0x7fffe9d23ac8, ob=0x7fff9f7e9008, dupflag=1599) at /home/zed/programmering/blender_master/blender/source/blender/editors/object/object_add.c:2243 #1 0x00005555575f20d5 in add_named_exec (C=0x7ffff0030288, op=0x7fff9e03b048) at /home/zed/programmering/blender_master/blender/source/blender/editors/object/object_add.c:2592 #2 0x00005555570ec4df in wm_operator_invoke (C=0x7ffff0030288, ot=0x7fffead0ab08, event=0x7fff9dcb0108, properties=0x7fffde6c6f08, reports=0x0, poll_only=false, use_last_properties=true) at /home/zed/programmering/blender_master/blender/source/blender/windowmanager/intern/wm_event_system.c:1343 #3 0x00005555570ecce2 in wm_operator_call_internal (C=0x7ffff0030288, ot=0x7fffead0ab08, properties=0x7fffde6c6f08, reports=0x0, context=0, poll_only=false, event=0x7fff9dcb0108) at /home/zed/programmering/blender_master/blender/source/blender/windowmanager/intern/wm_event_system.c:1576 #4 0x00005555570ef07f in wm_handlers_do_intern (C=0x7ffff0030288, event=0x7fff9dcb0108, handlers=0x7fff9e0615d8) at /home/zed/programmering/blender_master/blender/source/blender/windowmanager/intern/wm_event_system.c:2416 #5 0x00005555570ef860 in wm_handlers_do (C=0x7ffff0030288, event=0x7fff9dcb0108, handlers=0x7fff9e0615d8) at /home/zed/programmering/blender_master/blender/source/blender/windowmanager/intern/wm_event_system.c:2618 #6 0x00005555570f0f96 in wm_event_do_handlers (C=0x7ffff0030288) at /home/zed/programmering/blender_master/blender/source/blender/windowmanager/intern/wm_event_system.c:3093 - 7 0x00005555570e5885 in WM_main (C=0x7ffff0030288) at /home/zed/programmering/blender_master/blender/source/blender/windowmanager/intern/wm.c:425 - 8 0x00005555570e016e in main (argc=1, argv=0x7fffffffdd08) at /home/zed/programmering/blender_master/blender/source/creator/creator.c:520 ```
Note that this has nothing to do with appending, from default blender start, add a new empty scene, and try to drag-and-drop cube from default scene in there from outliner also crashes. Dummy mistake actually.
This issue was referenced by 3e072da45b
This issue was referenced by 3e072da45bee1ac5368b83c84839d2ccdde6e514
Reference: blender/blender#60432
