blender 2.8 doesnt open #60496
2 Participants
Reference: blender/blender#60496
Operating system: windows 10
Graphics card:geoforcegt54m
Broken:
2.8
installed and never onpened just stays in a grey screen
Added subscriber: @juanvla
sorry the graphic card is geoforce gt 540m
Which exact version of Blender did you download?
Can you try to start Blender using a console with the
--debug --debug-gpu
options and post the output here?Hello Jacques here is the blender version I downloaded it yesterday
blender-2.80.0-git.9390b2e645a6-windows64
can you tell me more how to open it with the console?
Best regards!
On windows you can find/open the console by searching for "cmd" in the windows search.
Then you have to figure out where your
blender.exe
file is. If you found it, hold down shift (or ctrl, not sure) and right click on the file.Then there should be an option to copy the file path.
Go back to the console and insert the path there. Then add the
--debug
and--debug-gpu
options.The full command should looks something like so:
C:\\...\\blender.exe --debug --debug-gpu
.Hit enter to execute the command.
Then copy all the text that is generated and post it here.
Hello Jacques, here is the copy of the text generated
Thanks. Unfortunately, you accidently wrote
--debug.gpu
instead of--debug-gpu
.Also check if your gpu driver is up to date.
sorry here we go again
Microsoft Windows [Versión 10.0.17134.523]
(c) 2018 Microsoft Corporation. Todos los derechos reservados.
C:\Users\Usuario>C:\Users\Usuario\Desktop\3D\BLENDER\blender-2.80.0-git.9390b2e645a6-windows64\blender.exe --debug --debug-gpu
Switching to fully guarded memory allocator.
Blender 2.80 (sub 41)
Build: 13/01/2019 17:11 Windows Release
argv- [x] = C:\Users\Usuario\Desktop\3D\BLENDER\blender-2.80.0-git.9390b2e645a6-windows64\blender.exe
argv- [x] = --debug
argv- [x] = --debug-gpu
read file
AL lib: (EE) UpdateDeviceParams: Failed to set 48000hz, got 44100hz instead
GPUTexture: create : TEXTURE_CUBE_MAP, RGBA16F, w : 2, h : 2, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_1D, RGBA8, w : 1, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1, h : 1, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_3D, RGBA8, w : 1, h : 1, d : 1, comp : 4, size : 0.00 MiB
Using OpenGL 4.3 debug facilities
GL application marker: Successfully hooked OpenGL debug callback.
found bundled python: C:\Users\Usuario\Desktop\3D\BLENDER\blender-2.80.0-git.9390b2e645a6-windows64\2.80\python
GPUTexture: create : TEXTURE_2D, RGBA8, w : 945, h : 26, d : 0, comp : 4, size : 0.09 MiB
GPUTexture: create : TEXTURE_2D, R8, w : 16384, h : 128, d : 0, comp : 1, size : 2.00 MiB
GL API other: Buffer detailed info: Buffer object 2 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_STREAM_DRAW) will use VIDEO memory as the source for buffer object operations.
GL API other: Buffer detailed info: Buffer object 2 (bound to GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (0), GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (1), GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (2), and GL_ARRAY_BUFFER_ARB, usage hint is GL_STREAM_DRAW) will use VIDEO memory as the source for buffer object operations.
GL API other: Buffer detailed info: Buffer object 3 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_STATIC_DRAW) will use VIDEO memory as the source for buffer object operations.
GL API other: Buffer detailed info: Buffer object 1 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_DYNAMIC_DRAW) will use SYSTEM HEAP memory as the source for buffer object operations.
GL API other: Buffer detailed info: Buffer object 1 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_DYNAMIC_DRAW) has been mapped WRITE_ONLY in SYSTEM HEAP memory (fast).
GPUTexture: create : TEXTURE_2D, RGBA8, w : 405, h : 26, d : 0, comp : 4, size : 0.04 MiB
GL API other: Buffer detailed info: Buffer object 4 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_STATIC_DRAW) will use VIDEO memory as the source for buffer object operations.
GPUTexture: create : TEXTURE_2D, RGBA8, w : 16, h : 32, d : 0, comp : 4, size : 0.00 MiB
GL API other: Buffer detailed info: Buffer object 1 (bound to GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (0), and GL_ARRAY_BUFFER_ARB, usage hint is GL_DYNAMIC_DRAW) has been mapped WRITE_ONLY in SYSTEM HEAP memory (fast).
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1318, h : 32, d : 0, comp : 4, size : 0.16 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1350, h : 20, d : 0, comp : 4, size : 0.10 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 234, h : 26, d : 0, comp : 4, size : 0.02 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 29, h : 414, d : 0, comp : 4, size : 0.05 MiB
GL API other: Texture state usage warning: Texture 0 is base level inconsistent. Check texture size.
GPUTexture: create : TEXTURE_2D, RGBA8, w : 205, h : 414, d : 0, comp : 4, size : 0.32 MiB
GL API other: Buffer detailed info: Buffer object 1 (bound to GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (0), GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (1), and GL_ARRAY_BUFFER_ARB, usage hint is GL_DYNAMIC_DRAW) has been mapped WRITE_ONLY in SYSTEM HEAP memory (fast).
GPUTexture: create : TEXTURE_2D, RGBA8, w : 234, h : 182, d : 0, comp : 4, size : 0.16 MiB
GL API other: Buffer detailed info: Buffer object 5 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_STATIC_DRAW) will use VIDEO memory as the source for buffer object operations.
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1115, h : 26, d : 0, comp : 4, size : 0.11 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1115, h : 23, d : 0, comp : 4, size : 0.10 MiB
GL API other: Buffer detailed info: Buffer object 6 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_STATIC_DRAW) will use VIDEO memory as the source for buffer object operations.
GL API other: Buffer detailed info: Buffer object 7 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_STATIC_DRAW) will use VIDEO memory as the source for buffer object operations.
GPUTexture: create : TEXTURE_2D, RGBA8, w : 56, h : 573, d : 0, comp : 4, size : 0.12 MiB
GL API other: Buffer detailed info: Buffer object 8 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_STATIC_DRAW) will use VIDEO memory as the source for buffer object operations.
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1115, h : 599, d : 0, comp : 4, size : 2.55 MiB
GPUTexture: create : TEXTURE_2D, DEPTH24_STENCIL8, w : 1115, h : 599, d : 0, comp : 1, size : 2.55 MiB
GPUTexture: create : TEXTURE_1D, RGBA8, w : 257, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_1D, RGBA8, w : 256, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, R11F_G11F_B10F, w : 1115, h : 599, d : 0, comp : 3, size : 2.55 MiB
GPUTexture: create : TEXTURE_2D, R32UI, w : 1115, h : 599, d : 0, comp : 1, size : 2.55 MiB
GPUTexture: create : TEXTURE_2D, RG16, w : 1115, h : 599, d : 0, comp : 2, size : 2.55 MiB
GPUTexture: create : TEXTURE_2D, RGB16F, w : 64, h : 64, d : 0, comp : 3, size : 0.05 MiB
GPUTexture: create : TEXTURE_2D, DEPTH_COMPONENT24, w : 1115, h : 599, d : 0, comp : 1, size : 1.91 MiB
GPUTexture: create : TEXTURE_2D, R16UI, w : 1115, h : 599, d : 0, comp : 1, size : 1.27 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 16, h : 16, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, R8, w : 16384, h : 64, d : 0, comp : 1, size : 1.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 527, h : 494, d : 0, comp : 4, size : 0.99 MiB
GL API other: Buffer detailed info: Buffer object 159 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_STATIC_DRAW) will use VIDEO memory as the source for buffer object operations.
GPUTexture: create : TEXTURE_2D, RGBA8, w : 388, h : 32, d : 0, comp : 4, size : 0.05 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 946, h : 32, d : 0, comp : 4, size : 0.12 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 311, h : 91, d : 0, comp : 4, size : 0.11 MiB
Hm, don't know what the actual problem is... Waiting for someone else to check.
Hello jacques problem solved I chequed the gpu driver is up to date and it wasn t.
Thanks!!! best regards!!
