New vertex groups cannot be operated upon ... until? #60517
7 Participants
Reference: blender/blender#60517
Operating system: Windows 10
Graphics card: GTX 970
example: 2.79b release
There is a problem with the way the Blender handles newly created vertex groups that causes numerous problems.
To recreate:
Using the weight paint brush in an empty space, or manually assigning a vertex to the vertex group in the properties window will allow the weight tools to work as expected. However this is not an acceptable workaround when using Bmesh to manager vertex groups.
Added subscriber: @sok0
untitled.blend
in the attached file the script fails on the newly created vertex group "Group":
AttributeError: BMElem[key]: invalid key, must be a BMLayerItem
If the vertex group is initialized such as by assigning vertices to the group manually, prior to running the script, then the script will run without errors.
untitled2.blend
For a new vertex group:
.verts.layers.deform.items() returns []
.verts.layers.deform.active returns None
For a vertex group that has had a manual weight paint brush stroke or vertex assignment in the properties panel, respectively:
[('', <BMLayerItem object at 0x000002D11EB10300>)]
Sorry for blowing up the thread, but found a solution: The following script will create the needed BMLayerItem object so that Weight Tools may be used on a newly created Vertex Group
Initilize VG for Tools.blend
Based on your new discoveries, could you please rephrase what the bug is?
Also remember that there should only be one bug per report. If you experience more bugs, create a separate report for each.
The bug is that Weight Tools do not work as expected, possibly because .verts.layers.deform.verify() is needed to fix it
Added subscriber: @ZedDB
I'm getting this with 2.8 if I follow the instructions in the description:
BLI_assert failed: /home/zed/programmering/blender_master/blender/source/blender/blenkernel/intern/DerivedMesh.c:2294, mesh_get_eval_deform(), at 'ob->id.tag & LIB_TAG_COPIED_ON_WRITE'
And the BT if I disregard the asserts:
@sok0, can you explain me what the "Fix Deforms" operation is supposed to do?
Could not find any useful information. The code for it seems to be bad in many regards.
Also I found this: #32406
Does not look like this has ever been corrected.
I've read the documentation and I assumed it was some kind of algorithm that adjusts ratios of bone weights for deforms that cause excessive clipping. In practice i've never seen it do anything.
Added subscriber: @Sergey
@ZedDB, i've made current master (
9d269a97be
) to work the same as 2.79 with "Fix Deform". There is no much more i can do here.The original report is about 2.79, and i can only make .280 work same as 2.79 in areas i am absolutely not familiar with.
Added subscriber: @iss
Still crashes in 2.83 in Fix Deforms operator code
MDeformVert *dvert
was nullThis issue was referenced by
101c3d4ce4
