Parametric coordinates and subdivision modifier different in 2.80 as in 2.79 #60524
5 Participants
Reference: blender/blender#60524
Win 10
I7-5820K
GTX1080 ti
Worked: 2.79
Broken: 2.80,
84c06e996a
, 2019-01-14Short description of error
The quadratic gradient texture seems to be broken in 2.80.
In 2.79, using the parametric output with a gradient on a plane object with 1 level subsurf give me a quick way to have a gradient around all the edges.
Load the blend file in attachment and render.
GradientTexture.blend
Added subscriber: @Clarkx
Added subscribers: @Sergey, @lichtwerk
The subdivision modifier seems to handle interpolation of Parametric differently [seems to not be interpolated but rather repeated over all generated geometry].
Not sure if this is actually correct in 2.79, but confirming for now and leaving up to @Sergey to decide...
quadratic gradient texture different in 2.80 as in 2.79to Parametric coordinates and subdivision modifier different in 2.80 as in 2.79Added subscriber: @JacquesLucke
This is probably just related to the new subdiv modifier which apparently produces a different topology.
Personally I would not consider this a bug. The fact that it worked in Blender 2.79 seems to be a happy coincidence.
I would not depend on the Parametric output for anything for mesh objects.
Also EEVEE renders yet another pattern on the object.
Assigning to @Sergey because he has to decide if this is considered a bug or not.
[EDIT: damn, you were faster ^^]
Ok, thanks a lot for the explanations and your hard work guys !
I will have to find another way to make this texture.
Added subscriber: @brecht
The better solutions for this is to create a UV map and Reset the UV coordinates. Then it works for all subdivisions levels.
Such things are tricky to be preserved 100% compatibility, sooner or later exact match will be lost. As @brecht mentioned, using UV for such an exact control will work way more reliable.
Thanks for the report, but will not consider it a bug.
