Warning is displayed when disabling viewport of constraint object
Operating system: Windows10 64bit
Graphics card: GTX1080
Broken: 2.80 84c06e996a7a-win64
  1. Display system cosole.
  2. Create two rigid bodies.
  3. Create one empty object and constrain the rigid body.
  4. Invalidate viewport of empty object with outliner.
  5. A message appears on the console.
If there are a lot of constraint objects, the response of the operation will be worse accordingly.
Also, if it is invalid, it is kept waiting for each operation (addition or deletion) of the object.
I am at a loss as to whether it is a bug or not.
In the attached file, if collection1 is invalidated, it will be displayed in large quantities.
If it does not come out there is possibility of environmental dependence, so I can not confirm it.
To avoid it, if you delete constraints of rigid body world setting, it will not appear at all.
Messages to be displayed:
find_node component: Could not find ID OBEmpty
add_relation(RigidBodyConstraint -> RBC.Object_1) - Could not find op_from (ComponentKey(OBEmpty, TRANSFORM))
add_relation(RigidBodyConstraint -> RBC.Object_1) - Failed, but op_to (OperationKey(type: TRANSFORM, component name: '', operation code: RIGIDBODY_TRANSFORM_COPY)) was ok
add_relation(RigidBodyConstraint -> RBC.Object_2) - Could not find op_from (ComponentKey(OBEmpty, TRANSFORM))
add_relation(RigidBodyConstraint -> RBC.Object_2) - Failed, but op_to (OperationKey(type: TRANSFORM, component name: '', operation code: RIGIDBODY_TRANSFORM_COPY)) was ok
add_relation(RigidBodyConstraint Transform -> RB Simulation) - Could not find op_from (ComponentKey(OBEmpty, TRANSFORM))
add_relation(RigidBodyConstraint Transform -> RB Simulation) - Failed, but op_to (OperationKey(type: TRANSFORM, component name: '', operation code: RIGIDBODY_SIM)) was ok
