Display issue in model corner when loop cutting
Confirmed, LowPublicTO DO
Broken: 2.79, 2.81
Worked: -
When creating and edge loop around de outside faces it creates in one of the cornes an extrange artifact
Create an edge loop across the outside faces of the model.
Blender file:
Artifact:
Was the case in 2.7x too:
Luckily it has no bearing on the resulting loop cut, but is a strange small display glitch with the loop cut tool and this exact type of geometry.
So, is it a regression?
Well, no. That's what I just wrote - this has always been the case. It is a bug, but not a new one. It should be fixed, but it's a fairly harmless display glitch that happens in rare instances. Not sure how to prioritise these kinds of things.
Jacques Lucke (JacquesLucke) lowered the priority of this task from 90 to 50.Jan 17 2019, 10:48 AM
Richard Antalik (ISS) changed the task status from Confirmed to Needs Information from User.Jan 22 2020, 11:49 PM
I have re-triaged this report and can not reproduce it. (original .blend file missing?)
Can you please check if this is still an issue in latest build?
https://builder.blender.org/download/
Dalai Felinto (dfelinto) changed the task status from Needs Information from User to Confirmed.Feb 6 2020, 4:30 PM
Dalai Felinto (dfelinto) changed the subtype of this task from "Report" to "Known Issue".
Dalai Felinto (dfelinto) renamed this task from Display bug in model corner to Display issue in model corner when loop cutting.Feb 6 2020, 4:32 PM
Dalai Felinto (dfelinto) triaged this task as Low priority.
Dalai Felinto (dfelinto) updated the task description. (Show Details)
Campbell Barton (campbellbarton) changed the subtype of this task from "Known Issue" to "To Do".Sep 3 2020, 6:49 AM
Campbell Barton (campbellbarton) added projects: Good First Issue, Restricted Project.
Campbell Barton (campbellbarton) moved this task from Backlog to Papercuts on the Modeling board.
I believe the bug is in: view3d_preselect_mesh_edgering_update_edges_from_edge
in editmesh_preselect_edgering.c
Looks like its creating an extra edge at the end. I don't much about how BMesh edges work but I'd liked to take a crack at it over the next couple of days for learning purposes.
