Greace Pencil 2.8, keyframes problems #60621
Reference: blender/blender#60621
Operating system: mac os x 10.14.2
Graphics card:
Broken:
(example: 2.80, downloaded 11.01.19
Key frames don't show in the Dope sheet but only in the Graph Editor
Key frames changes appear where no key frames where created, without a way to modify the changes.
The short video linked herein, would provide you with the best visualisation, I hope.
name
I could access them only through the Graph Editor.
You can note that even thought the position remains grey, its values changes by the time. I also tried to go to the last frame and entered the same value, this didn't change the outcome.
When I added to shadow, highlight strokes for the body and ticked the clamp option all worked fine.
That was not the case with the arm layer. As you can note the shadow still appear above the arm. I.e the stroke displays all points regardless of the Clamp.
Of course, I might miss some knowledge to tweek it properly. I looked for info online, I didn't find any information about it, so I report it as a bug.
Thanks for your hard effort and for the consideration.
Cheers,
DB
Added subscriber: @donbonbon
Added subscriber: @lichtwerk
Please only report one issue per report.
reg. 1) "Key frames don't show in the Dope sheet but only in the Graph Editor":
Your Dopesheet is in
mode [this only displays timings for all grease pencil sketches], to see the armature animation, change it toDope Sheet
For the other issues it is really better to open separate reports (and it would be good to have a simple example blendfile that shows the issue [e.g. I cannot reproduce the shifting mentioned in 2.) when doing this from scratch here])
Added subscriber: @antoniov
For the first issue I would like to ask @antoniov if the grease pencil context in dopesheet should also include armatures? [I guess current way is by design, just hesitating to close this...]
Thanks Philipp,
I attache herein the Blend file.
I noted you request of seperating the observations for future issues. However, as I don't want to create an additional confusion, I attached the Blend file only to this particular task. If needed kindly adivse, I'll attach it to the other tasks as well.
DB{F6330489}
Cheers, DB
Added subscriber: @WilliamReynish
This is by design. So that's not a bug. Set the Dopesheet to Action Editor or Dopesheet.
You can't change or see the GP keyframes unless you set the Dopesheet to Grease Pencil. So that's not a bug.
This depends on how you set the Dopesheet - for GP or actions, or whatever. Doesn't appear to be a bug.
In your file, you have parented your GP object to an Armature which is keyframed to move. So that's not a bug.
I don't get this. In your file, you only added bones to the arm, and only they are animated. What would you expect to see?
I'm marking this as Invalid.
If you ever do find a bug that can be reproduced, add a report for this one issue only, and add a blend which demonstrates the issue.
Thanks.
