grid fill bug on repeat last operation #60777
Reference: blender/blender#60777
Operating system: windows 10
Graphics card: GTX 960m
Broken: 2.80.0-git.7f40d553f903-windows64, 2019-01-22
(example: 2.79b release)
(example: 2.80,
edbf15d3c0
, blender2.8, 2018-11-28, as found on the splash screen)Worked: (optional)
grid fill does differently when done with "repeat last operation/shift + R",
the bug does not happen consistently even with almost identical mesh
Based on the default startup or an attached .blend file (as simple as possible).a99cc76934b589b3901a51333575cf48.mp4
here is the attachment of the files, thank you for such a great community
bug_grid-fill.blend
Added subscriber: @hirvijk
Added subscribers: @ideasman42, @JacquesLucke
I can reproduce the issue. I'm just not sure if this really is a bug. I suppose that @ideasman42 knows that. If he says it's a bug, I can try to fix it.
alright thank you for acknowledging this
Grid fill depended on being able to initialize it's properties to match the selection, however "Repeat Last" ignored
PROP_SKIP_SAVE
.Since there are many operators that work this way, changed the behavior of "Repeat Last"
1d908bffdd
.thank you for resolving this issue very quickly, seeing how the bug is resolved i construct a different problem, which give me an apparent result which i don't know if this is intentional and that is before (2.80 2019-01-24) using transformation tools will let you use repeat last operation, now you cant do that anymore
below are another different command that i use very often that i've checked
below are another different command that i never use but i've checked just for the sake of the bug fixing
This issue was referenced by
3d8cbb534f
Applied alternate fix which keeps repeat transform working.
e63c360bcd
3d8cbb534f
Wanted to avoid checks for this special case but seems we cant avoid it.
i've just tested the newer version and the results are consistent throughout different simple and complex mesh holes that are made of either polys and tris.
this is amazing, i hope you have a great weekend, thank you.
