Compositor RGB Curves artefacts with 'film like' option when using individual channels (only works correctly with the 'master' curve) #60940
6 Participants
Reference: blender/blender#60940
Operating system: SUSE Leap 15.0
Graphics card: NVidia GTX 560ti (official drivers)
Broken: 2.80,
5632e1b525
, x86_64 linux, 2019-01-24 (buildbot)Short description of error
Compositor RGB Curves node gives false colours when set to 'Film like' and when any of R,G,B channels are adjusted. Adjustment of C channel alone is OK.
sidenote; Constant hue adjustment is definitely an interesting feature to have! But since film often has various hue shifts going on, if anything, 'Standard' is possibly closer with a typical S-curve - a bias to cyan, magenta, yellow in the highlights corresponding to the curve shoulder.
'Hue hold' or 'Hue lock' could be alternative names.
Example .blend
compositor_rgbcurves_film-like_artefacts.blend
Load attached .blend, render.
Ref:
https://developer.blender.org/rB4de7c0c3105a80d244dd9f2078c310331873a16b
Notes:
Added subscriber: @intracube
This comment was removed by @Jeroen-Bakker
Added subscriber: @Jeroen-Bakker
Added subscriber: @lichtwerk
Not knowing the internals well, this really looks "off".
It is especially apparent with soft, gradient like areas, so it breaks quickly with Bloom (like in this case), Glare, Blur and such...
There is a similar example in the comments of
4de7c0c310
.Would have to check the implementations in other software to get a sense if this is "broken by design" or an actual bug in the shuffling of channels or so...
Maybe it is also expected to break if done on a particular channel [and not done on the "master"
C
curve only]?Hi, I think it was explained that the film option is only designed to work with adjustments to the 'C' (luminance) channel.
So the simple solution would be to disable the R,G,B channels in that mode.
Also reconfirmed with @Jeroen-Bakker that this is only correctly working with the
C
curve.So fix is a UI thing: will hide the
Film like
option when inR
G
orB
curves, and hideR
G
B
when inFilm like
...Compositor RGB Curves artefacts with 'film like' optionto Compositor RGB Curves artefacts with 'film like' option when using individual channels (only works correctly with the 'master' curve)Added subscriber: @Alex-9
Added subscriber: @rwman
