Progressive Rendering: generate video preview #60980
1 Participants
Reference: studio/flamenco#60980
Having a video preview (at least of the first sample chunk) would improve usability of the progressive rendering, as only a list of linear EXR files isn't all that useful.
This would require correct conversion from the linear EXR files to the desired output colour space. Options to investigate are:
ocioconvert
tool to convert the files, then feed to FFmpeg.BAT
maybe?) from the original blend file, then fill the VSE with the EXR sequence and render to PNG.Added subscriber: @dr.sybren
Output to JPEG would also be good enough (w.r.t. PNG).
Implemented as the 2nd option (open blend file, create scene, fill VSE, render) in
3371e5d
,b3c620b
, and a bunch of commits on the Worker
