[Addon] Import images as planes - addon disabling bug #60986
Closed
opened 2019-01-29 17:02:08 +01:00 by Ivan Santic · 5 comments
Operating system: Windows 10
Graphics card: GTX 980 Ti
2.80, 957b4547aeeb, Blender 2.8, 2019-01-28 22:11
Worked: addon works but it outputs an error message popup if it gets disabled/enabled.
Short description of error and the console output
`Exception in module unregister(): 'D:\\moth3r\\Portable\\Blender 2.80\\2.80\\scripts\\addons\\io_import_images_as_planes.py'
  File "D:\moth3r\Portable\Blender 2.80\2.80\scripts\modules\addon_utils.py", line 446, in disable
    mod.unregister()
  File "D:\moth3r\Portable\Blender 2.80\2.80\scripts\addons\io_import_images_as_planes.py", line 1175, in unregister
    if check_drivers in bpy.app.handlers.scene_update_post:
AttributeError: 'bpy.app.handlers' object has no attribute 'scene_update_post'
Error: Traceback (most recent call last):
    mod.unregister()
AttributeError: 'bpy.app.handlers' object has no attribute 'scene_update_post'`
If you disable the addon you will get that message in the console. To enable you have to click twice now. First click error message and then it gets enabled 2nd time.
**System Information** Operating system: Windows 10 Graphics card: GTX 980 Ti **Blender Version** 2.80, 957b4547aeeb, Blender 2.8, 2019-01-28 22:11 Worked: addon works but it outputs an error message popup if it gets disabled/enabled. **Short description of error and the console output** ``` `Exception in module unregister(): 'D:\\moth3r\\Portable\\Blender 2.80\\2.80\\scripts\\addons\\io_import_images_as_planes.py' Traceback (most recent call last): File "D:\moth3r\Portable\Blender 2.80\2.80\scripts\modules\addon_utils.py", line 446, in disable mod.unregister() File "D:\moth3r\Portable\Blender 2.80\2.80\scripts\addons\io_import_images_as_planes.py", line 1175, in unregister if check_drivers in bpy.app.handlers.scene_update_post: AttributeError: 'bpy.app.handlers' object has no attribute 'scene_update_post' Error: Traceback (most recent call last): File "D:\moth3r\Portable\Blender 2.80\2.80\scripts\modules\addon_utils.py", line 446, in disable mod.unregister() File "D:\moth3r\Portable\Blender 2.80\2.80\scripts\addons\io_import_images_as_planes.py", line 1175, in unregister if check_drivers in bpy.app.handlers.scene_update_post: AttributeError: 'bpy.app.handlers' object has no attribute 'scene_update_post'` ``` **Exact steps for others to reproduce the error** If you disable the addon you will get that message in the console. To enable you have to click twice now. First click error message and then it gets enabled 2nd time. Based on the default startup or an attached .blend file (as simple as possible).
Author
Added subscriber: @moth3r
Added subscribers: @lichtwerk, @ZedDB
@lichtwerk is this something for you?
Philipp Oeser self-assigned this 2019-01-30 09:23:48 +01:00
This issue was referenced by 157019dd05
This issue was referenced by 157019dd05532720ac3f1084a721057fd9c3d712
Member
Reference: blender/blender-addons#60986
