Subdivision modifier artifacts in Blender 2.80 #61145
Reference: blender/blender#61145
Operating system: Windows 10
Graphics card: 1080ti
Broken:
2.80 downloaded on the 3rd of Feb, 2019 as found on the download beta section
Some artifacts around the out circle in the blend file, this is not present in Blender 2.79
load attached file, doesn't matter if it is Cycles or Blender the artifact is present.
ukelele.blend
Added subscriber: @cyberangel67
Added subscriber: @Manuli
I Downloaded your file, Next time please use File > Export > Automatically pack files into .blend to export all your textures, HDRI's :)
Textures missing from your files....
I rendered your scene but I got clean Image. I think the problem is from your side...
Click on Image to see @ full resolution
If you are using Windows 10 please check if you have 32-bit capable screen.
8-bit screens can cause banding issue...
Check it Start menu > settings (gear icon) > system > Display > Advance display settings
If your screen settings shows 8-bit as in the following Image then the problem is your screen
Click on the preview to see full Image
Sorry I am new to Blender, didn't know about that option. And I don't see the option to automatically pack files.
I just looked at your image and the artifact is there.
If you look near the ring or hole and the outer ring you will see triangles, those triangles don't appear on when in Blender 2.79.
Have attached the rendering from Blender 2.79 and circled the artifacts in your render in the following two images.
It's not a bug! you have to use smooth feature. (This is same as we set phong in Cinema 4D)
Here's how you can do this >
BTW, Sorry for wrong step for texture export, This is how you can do this >
File > External Data > "Automatically pack files into .blend" (This is when you want to export or share files with others you should tick this.)
Hope this helps.
So are you saying that even though I am using Cycles in 2.79 and 2.80, I now have to retouch all my work to work in Blender 2.80?
Seriously!!
Added subscribers: @Sergey, @lichtwerk
To me it looks like the subdivision modifier still has problems with ngons.
(unsure why we would have to enable autosmooth...)
Simpler file here:
#61145.blend
@Sergey: is this a know thing?
Strange artifacts in Blender 2.80to Subdivision modifier artifacts in Blender 2.80Yes, Blender 2.8 is still not a stable version. So please better you use it for testing purpose only. I told him a temporary way "Auto Smooth". but Developer will solve the problem if they find anything... Thank You.
What ever happened to this bug, as Blender is now released the artifact still exists in Blender 2.80, where as it doesn't in Blender 2.79
Added subscriber: @HDMaster84
I just tried this with current master and got the same result, so this is still valid. I also made an even simpler file with just 4 vertices and using Simple Subdivision.
#61145.blend
Since there are various very simple workarounds like flat shading (e.g. with autosmooth), triangulate modifier, apply modifier and enter editmode, ... I would consider this low priority.
