Workbench poor antialiasing in Xray mode #61202
5 Participants
Reference: blender/blender#61202
Operating system: Windows 10
Graphics card: GTX1080Ti
Broken: 2.80
Worked: 2.79
Antialiasing in Workbench in Xray mode in Blender 2.8 is significantly worse compared to Blender 2.79. In some cases it's so bad it significantly impacts modeling efficiency in a negative way. Check the attached screenshot:
1, Create a mesh and go into edit mode
2, Enable select through (next to overlays)
3, Observe extremely jagged lines
Result: Lines are extremely jagged regardless of multisample setting in preferences
Expected: Lines should be smooth
Added subscriber: @Rawalanche
Added subscriber: @nacioss
Mine get antialiased...
Please try to go in File and select Load Factory Settings, then try again to see if this solved the problem
Added subscriber: @PeterBaintner
Confirm on same windows 10 and GTX 1080 Ti.
1, You are using completely different setup, including operating system. With such a difference, you can't immediately jump to conclusion. Obviously, I tried factory defaults.
2, No, yours doesn't get antialiased. You are just using such a big resolution that you notice it less:
3, It requires a bit more complex scenario than just a simple cube to correctly see the result. Simple cube looks quite OK even on my monitor with half the resolution of yours:
Added subscribers: @fclem, @ZedDB
@fclem I'm guessing this is already a known issue?
In some cases, it's truly extremely bad. Here's comparison between 2.79 (top) and 2.8 (bottom):
I think they fixed it
Can't confirm on
d3870471ed
This type of aliasing have been fixed by now. Closing.
