can't select the same material in multi edit mode
Operating system: windows 10
Graphics card: nvidia geforce gtx 960
Broken:
2.80, c6cbcf83d015, blender2.8, 2019-2-14
  1. create a pair of objects
  2. append different materials to different faces
  3. next in multi-edit mode try to choose 1 material, blender will select wrong faces
Sebastian Parborg (zeddb) triaged this task as Confirmed, Medium priority.
I mined more
2.80 (sub 45), 893fa598319e, 2019-02-24 22:02
How to reproduce:
Here is video. And small difference in order of actions determines bug appearance.
At first sphere I made spot selection before I add material slots, and on the second I add material slots at first.
No matter if all sphere was selected or unselected. It causes bug.
And only the way: «Select spot->Add material slot->Assign» (repeat for each spot) work well.
Thanks for reporting. The issue is that assigning and selecting is based on the index of the active material in the UI. I'm working on a fix.
Just submitted a patch: D4441.
Assigning materials is not working as intended though. I'll try to fix it in a different patch.
